Old 08-10-2013, 11:01 PM
rizzkid12 rizzkid12 is offline
Vehicle: 2013 Ram1500 4x4 3.6l 8 speed
Trim Level: Tradesman
rizzkid12 is on a distinguished road
Default 3.6L engine cover removal?
Just did an oil change on my 2013 ram 1500 4x4 3.6l engine. Removing the oil filter would have been a bit easier if I could remove the plastic engine cover says( has 3.6L on it).
How do you remove it? I tried puling up firmly ion various locations, no luck.
Also I noticed a vacuum line near the oil filter with a plastic fitting which was not connected to anything. It looked like a black plastic connector that usually goes to a PVC valve. Anyone else notice this?
Old 08-11-2013, 12:50 AM
hattitude's Avatar
hattitude hattitude is offline
Vehicle: 2013 Ram 2500
Color: bright white
Rep:24
hattitude is on a distinguished road
Just went through the same thing.........
Thought I broke my truck.......
I couldn't see an easy way to pull the cover, so I left it on. Doable, but tight.
When I got finished, I saw that plastic fitting. I figured I obviously pulled it out, while messing with the filter.
I spent a bit of time trying to find out where it went. There are absolutely no open plugs, within the reach of that hose fitting. Plus mine had a clip that held it to another hose... that minimized it's reach, again, nothing within reach to plug it in.
If it pulled out of somewhere, I couldn't find it... and I looked hard! I left it where I found it and the truck's been running fine, no codes....
I want to buy a shop manual, I just can't find a printed version and I don't like the digital manuals...
OP, you are not alone
I too would love to know the trick to pulling the cover......
If someone can confirm that fitting goes no where, I'd love to hear that too...
Old 08-11-2013, 11:25 PM
Thanks Hattitude
anyone else?
Old 08-16-2013, 11:17 AM
hesm70 hesm70 is offline
Trim Level: SLT w/Big Horn
Color: Deep Cherry Red
hesm70 is on a distinguished road
Default 3.6L Engine Cover Removal
So, I assume the filter can will clear the cover without removal but I see like you guys have said that it is awfully tight. We have a 2011 Jeep Grand Cherokee with the same motor and there is a access door which makes removal and installation easy. Now finding it when one doesn't know the filter is on top of the engine is a whole different monster.
Old 08-16-2013, 12:09 PM
spp spp is offline
Vehicle: 2008 Jeep Wrangler
Trim Level: Sahara
Color: Steel Blue
Rep:106
spp will become famous soon enoughspp will become famous soon enough
I haven't actually seem the Pentastar in the Ram but if it is anything like the Wrangler one, there are two mounting points in the middle/front and two "hinge" clips on the back. Lift up to disengage the front part of the cover and then pull forward to disengage the back.
Pictures...
Your mileage may vary, your own risk, etc.
Old 08-19-2013, 09:08 PM
thanks for the replies, but it is not like the Wrangler cover. I do not see hinges. I even looked under the cover using a mirror and cannot see any attachment points. I guess there there but I pulled it up very hard in numerous locations with no success.
Old 08-22-2013, 02:10 PM
Artful Dodger Artful Dodger is offline
Vehicle: 2013 Dodge Ram 1500
Rep:12
Artful Dodger is on a distinguished road
Default How to remove cover on 3.6L Pentastar
The cover is actually part and parcel with the air intake system going from the air filter box to the intake manifold.
First remove the 2 large hose clamps on either end. Then unplug the electric fitting and the hose fitting. Next, reach to the back of the cover and, pulling up, dislodge the cover from the 2 rubber-mounted pins that hold it in place. Then from the front of the truck pull the whole operation forward, removing it from the intake manifold and at the same time it will dislodge itself from the air filter connection. Take it to the bench, turn it upside down and you'll see how the whole thing is made.
I've attached several pics to show you what this looks like.
It's fairly simple to remove this cover once you see how it works but it's much more difficult to replace. I needed to get one leg right inside the engine compartment and with some effort got it back into position. I'm sure the next time it will be easier. However, if I can possibly get the oil filter replaced without having to take the cover off that's the simpler way to go.
I haven't had to replace the filter yet as the unit has only 800 km to date. It came with the 3.21 rear end and at present is delivering 8.9L/100km
Old 08-22-2013, 09:57 PM
fishin4ladyz fishin4ladyz is offline
Vehicle: 2013 RAM1500 QUAD 4x4 3.21rear
Trim Level: tradesman
Rep:14
fishin4ladyz is on a distinguished road
You beat me to it. Just checked my truck out today and came the conclusion that it was one piece with the air hat thing. Sure is ugly. I know the engine isnt much to look at but that plastic junk is icing on the cake. Thanks for taking the time to snap some pics!
Old 08-25-2013, 03:44 PM
hattitude's Avatar
Color: bright white
Rep:24
Thanks for the info..... been dying to figure this out and it had me stumped. I just wouldn't believe it was part of the air intake system, even thought that is what it looked like....
Thanks again!
Old 08-25-2013, 08:54 PM
marvin02's Avatar
marvin02 marvin02 is offline
Trim Level: Tradesman QC 4x2
Rep:30
marvin02 is on a distinguished road
The oil filter comes out fine without removing the cover. It is a snug fit but not difficult. Pics Here
