Old 08-11-2013, 10:29 AM
molina425's Avatar
molina425 molina425 is offline
Vehicle: 2012 Dodge Ram 1500 Sport
Color: Black-PX8
Rep:19
molina425 is on a distinguished road
Default Want to go back to stock.NEED TONS OF HELP PLEASE
So when i first bought my truck i loved my stock radio and features like uconnect and and all of that working flawlessly. My problem now is i replaced my stock radio with an aftermarket jvc and want to switch back.Needing to know what all would be involved to make it happen and still have all my other electronics working perfectly with it all(play dvds while driving,speaker system) for example. i currently have 5 t.v's in my truck and subs and amp and want to add the factory reverse camera also once i install the stock radio back in.Im sure its probably going to take alot of money and alot of work to get this done so was hoping you guys could help me out. My stock radio model number is p05091170ac. As far as uconnect goes im not sure if when switched to aftermarket radio they removed any components of it.like microphone and things like that to talk to the radio.
Old 08-11-2013, 07:37 PM
astroman54's Avatar
astroman54 astroman54 is offline
Rep:52
astroman54 will become famous soon enough
The radio you have is the RBZ.. (look at the lower right corner of the radio to make sure what I looked up is correct).. If it is, then there should be a separate Uconnect module located on the outer kick panel on the passenger side.. You can see it by fully lowing the lower glove box and looking toward the outer wall. They most likely just disconnected it (look for a connecter nearby the uconnect module).. As long as they didn't remove any of the factory connectors, there is a good chance you can just plug everything back in.. If not, then you will need a lot of luck..
The factory place for the microphone was the rear view mirror.. Look for two "grills" on the top of the mirror which are the two microphones.
To do everything you want with the stock radio, you will need a Lockpick or similar device to turn on the DVD function while driving.
Andy
Andy
2009 Dodge Ram 1500 Sport Deep Water Blue Crew Cab Hemi 4x4
Old 08-11-2013, 08:00 PM
molina425's Avatar
Color: Black-PX8
Rep:19
First i want to say thank you for taking time to help me. I need as much as possible right now.lol
Well yes it is the RBZ radio.
is this the module you are reffering to?
Dont see any unconnected wires anywhere but also done see any missing either.would there be anywhere else i can look for it where it plugged in to besides the module possibly? where would that be?
Ok i see the mics on the rearview.
What do you think would be needed to be able to plug all my tv's into it? is there anything for this?
Old 08-11-2013, 08:29 PM
molina425's Avatar
Color: Black-PX8
Rep:19
Well i double checked and there is one place where im guessing a wire would be plugged in to not sure thou since i cant seem to find any unconnected wires anywhere,
Old 08-11-2013, 09:53 PM
Rep:2664
I THINK that the smaller square plug in the center on the back of the radio is for the backup camera
http://www.google.com/imgres?imgurl=...ed=0CEIQ9QEwBw
http://www.google.com/imgres?imgurl=...AE8qWkz-1_M%3A
Good Luck
Old 08-11-2013, 09:57 PM
molina425's Avatar
Color: Black-PX8
Rep:19
Good Luck
Well the pictures I posted arent of the radio its of the uconnect module.wondering if im missing a plug in or if its always been empty. But for future reference thou thank you since I will be putting in the reverse camera also.
Old 08-11-2013, 10:07 PM
Rep:2664
look at the second image that I posted
who ever posted it, marked what the plugs are for
hopefully it is correct
Old 08-11-2013, 10:11 PM
molina425's Avatar
Color: Black-PX8
Rep:19
I checked both links its the same picture thou. Doesnt show anything labeled. Are you talking about the pic that I put up? I labeled it with the red lettering to show what was connected on my uconnect module already to see if that one thats missing was supposed to have something plugged into it.
Old 08-11-2013, 10:22 PM
Rep:2664
this image is the one that I mentioned
also look at the other images to the right of the screen
Old 08-11-2013, 10:30 PM
molina425's Avatar
Color: Black-PX8
Rep:19
Oh ok well that seems simple enough.on the labeled picture of the radio it doesnt have the little white squared plug in on it like my radio does. What do you think that would be for?
