Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 05-17-2013, 01:53 AM
amarillo amarillo is offline
Vehicle: 2007 Dodge Ram 2500
Trim Level: BigHorn
amarillo is on a distinguished road
Default O2 sensor replacement problem (pics included)
The good news is the fuel filter was a breeze to replace. The bad news is that I ran into a snafu trying to get the bad oxygen sensor out.
My truck is a 2007 Ram 2500 with the 6.7 diesel. The error code indicates sensor 1 bank 1 is bad. I have purchased a new sensor, but can't get the old one out due to some heat fabric that is wrapped and clamped around it. I tried to get the clamps off without destroying them, but it didn't seem possible. Is there anyway to get the sensor out without taking the fabric off? I tried for a half hour and there just doesn't seem to be enough room around the nut for the wrench to grab on. Any advice is much appreciated!
First pic is a view from the bottom. The middle clamp is a little chewed up since I tried to get it off without breaking it.
View of the sensor from the top/side.
Old 05-22-2013, 08:01 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
free bump
free bump
Old 05-22-2013, 08:34 AM
tjbiker031's Avatar
Vehicle: 2002 Dodge Ram
Trim Level: SLT - Quad Cab
Color: Graphite Metalic
Rep:118
Honestly i would just cut those clamps off and put hose clamps on them. The heat sheilding should prevent them from melting if you are concerned with that.
Also to get that subborn SOB off, I would just cut the wire at the sensor, double wrench it (useing the box end) with the largest wrench possible and use your friend, Mr Leverage, to do the hard work...just watch your knuckles.
You can also use a special socket make for removing O2 sensors, but i would never try a line wrench on these (it always ends badly)
Old 08-19-2013, 01:29 PM
hollonator's Avatar
hollonator hollonator is offline
Trim Level: SLT Quad Cab 4x4
Color: Flame Red Clearcoat - R4
hollonator is on a distinguished road
Pretty sound advice, I don't think I would cut the cable just yet incase there is a way of putting in the new O2 sensor without having to tie wires together. Mr. Leverage can still be used just have to have a wrench with 2 open ends if you don't cut the cable.
2007 Dodge Ram 1500 SLT Hemi 4x4
Custom Flowmaster 50 Series HD Exhaust
