Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 5.7L (345 cu in) HEMI V8 Specific Topics
Old 08-16-2013, 01:32 PM
RamRoy RamRoy is offline
Vehicle: 2014 Dodge Ram
Trim Level: BigHorn
Color: Deep Cherry
Rep:15
RamRoy is on a distinguished road
Exclamation Changing Plugs help (Pictures)
It's been awhile since I've been in here. I've used several suugestions in here and they all worked (changing out power side mirror and fixing a leak via the third break light). Now it's time to change spark plugs on my 5.7 hemi. A long tiime ago I saw a guy posted pictures of the whole process. Anybody got that link handy.
Old 08-17-2013, 10:40 AM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:554
I did mine from the top and it was pretty easy
Laid on top of the engine on a big thick moving blanket to reach the hard ones
(Drivers side near the brake booster)
You dont have to remove the grill,
I just had it off to add my intercooler for my supercharger install, right after the plug change
Here's a few You-Tube vid's that show the same method I used...
Make sure you have an actual spark plug specific socket ,
that's either magnetic or has a rubber fitting to pull the old plugs out.
You'll also need several extensions from 1.5" to 2.5"
because you'll have to add/remove them one section at a time under the brake booster where space is limited.
Old 08-19-2013, 03:15 PM
Trim Level: BigHorn
Color: Deep Cherry
Rep:15
Thank you...I will be attempting this within the next few weeks.
Old 08-19-2013, 03:19 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
also you can take the driver side wheel off and remove the fender lining with just a few screws and access the ones by the booster easier
Old 08-19-2013, 03:21 PM
Trim Level: BigHorn
Color: Deep Cherry
Rep:15
Sounds good...thank you as well.
Old 08-20-2013, 10:54 PM
Color: green
Rep:657
i would do the tire removal. looks like it makes it easier.
