Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Powertrain > V6 Specific Topics
Old 08-12-2013, 01:34 AM
kaosblacksmiths kaosblacksmiths is offline
Vehicle: 91 dodge ram 250 day van
Engine: 1988-1991 239ci (3.9L) LA V6 125hp
kaosblacksmiths is on a distinguished road
Default 91 250 ram day van oil problem
hi not sure if im in the right bit but i have a v6 3.9 and it is using loads of oil i cannot see any leaks and the water and oil are clear it smokes a little bit but it has done over 300000 on the clock can anyone help please
Old 08-12-2013, 02:13 AM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
Valve cover gaskets, valve stem seals and guides, possibly rings as well. Might have a gusher from the oil pressure sending unit.
Old 08-12-2013, 09:56 AM
crazzywolfie crazzywolfie is offline
Vehicle: 81 91 93 dodge
crazzywolfie is on a distinguished road
you may want to do a compression test. with that many miles on a motor it may be burning oil. could possibly try using some of that oil additive that is suppose to help boost compression by cleaning things.
91 & 81 d150 carburated 318's 93 R.C. F.I.318
