Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > LD RAM > 2011 Dodge Ram Forum
Old 08-12-2013, 05:52 PM
11silverslt's Avatar
11silverslt 11silverslt is offline
Vehicle: 2011 ram slt quad cab
Color: bright silver
Rep:19
11silverslt is on a distinguished road
Default Replacing stock res radio
Thinking about replacing my stock res radio with an Alpine INE-S920 HD nav radio. Anyone do this or have this radio. Any comments or advice is always appreciated .
Old 08-12-2013, 07:51 PM
ajd76's Avatar
ajd76 ajd76 is offline
Vehicle: 2015 Dodge Ram 1500 CC
Trim Level: Lonestar 4x4
Color: Max Steel
Rep:115
ajd76 will become famous soon enoughajd76 will become famous soon enough
Have you searched for posts regarding radio replacement yet? I only ask because Dodge stereos are 1.5(ish) DIN. Your Alpine is a double DIN which means there will be some fit issues which will require you to alter your dash a bit.
Old 08-12-2013, 07:58 PM
Rep:19
I am aware of the mod to the sub dash and was thinking of getting radio from Crutchfield, they include all parts necessary and a wiring harness with purchase..
Old 08-12-2013, 10:41 PM
ajd76's Avatar
Color: Max Steel
Rep:115
Yeah, they're great to work with. Personally, I was a little squeamish about cutting the sub dash, so I just bought and installed an RBZ radio instead.
Good luck with your install!
Old 08-13-2013, 02:41 PM
Rep:19
Thanks for the input.
Old 08-19-2013, 07:40 PM
fivehead fivehead is offline
Vehicle: 2011 Ram 1500
Color: Gold
fivehead is on a distinguished road
Hi 11silver,
I put a INE-S920HD in my 2011 Bighorn. I used a metra mounting kit for the dash trim, and used a dremel to cut the bottom piece of plastic sub-dash. It cut out like butter, and took about 15 minutes. I also made two small slices in the metal frame inside, so I could bend the metal back a little bit. At first I was scared to be carving out my truck, but I took the plunge and it turned out to be easy.
Old 08-19-2013, 07:52 PM
BryBry13's Avatar
BryBry13 BryBry13 is offline
Vehicle: 2012 Ram 1500 Express
Color: Mineral Gray Metalic
Rep:33
BryBry13 is on a distinguished road
It will look something like this (Radio I put in is a Pioneer) with the metra trim kit. Trimming the dash isn't that bad. A Dremel is a wonderful tool to use.
Smitty Built Cab Length Nerf Bars, Wade SureFit Mats, LED License Plate & Interior Bulbs, Upper and Lower Billet Grille Inserts, Debadged, Pioneer AVH-X5500BHS, Boyo Back-up Cam, Flowmaster Super 40, Flowmaster 5" Tips, DB-ALL Remote Start, Mcgaughy's 2" Rear Drop Coils, Chrome Brake Painted Drilled & Slotted Rotors, Power Stop Ceramic Pads, MGP "RAM" Caliper Covers, 22" Dolce DC-46 Wheels, Nitto NT420s 305/45R22 Tires ........... So Far............
Old 08-19-2013, 08:39 PM
Rep:19
Thanks guy's I am a little hesitant to cut up the truck, but I cant afford a new 48,000 sport with all the toys so.............. chop chop.
Old 08-19-2013, 09:14 PM
mgbighorn mgbighorn is offline
Color: True Blue
Rep:50
mgbighorn will become famous soon enough
i just picked up an ren radio, i know it dosent have nav but it was the best $300 i spent on the truck so far.
after haveing aftermarket heads in other vehicles that never look right i decided to go with a stock unit
