Old 08-18-2013, 10:39 AM
DuceTheCapo's Avatar
DuceTheCapo DuceTheCapo is offline
Vehicle: 2013 Ram 1500 Laramie
Color: Max Steel
Rep:30
DuceTheCapo is on a distinguished road
I had an issue trying to connect the a/c line back to the body. I ended up only reconnecting on of the screws and had to the leave the one by the airbox unfastened.
Old 08-18-2013, 11:54 AM
Codesman's Avatar
Codesman Codesman is offline
Vehicle: 2012 2500 crew cab
Color: Mineral Gray
Codesman is on a distinguished road
Think I will wait till then. Talked myself into it. Like the"snorkel" tube to get air from under the truck.
Old 08-18-2013, 12:12 PM
Color: Max Steel
Rep:30
I mean it works and I'm happy with it but if you want something year specific than you should wait.
Old 08-26-2013, 12:16 AM
txrobtrx txrobtrx is offline
Vehicle: 2013 1500 Laramie Longhorn
Trim Level: Laramie Longhorn
Color: Brown/Gold
Rep:60
txrobtrx will become famous soon enough
I installed mine on Friday and I guess I got lucky because I had no issues moving the AC line back and forth. I am not very mechanically inclined so I took a ridiculous amount of time doing everything slowly but got it to work without issues.
Old 08-26-2013, 09:46 AM
Color: Max Steel
Rep:30
Were you able to bolt the A/C lines back?
Old 08-27-2013, 07:52 PM
Whiplash's Avatar
Whiplash Whiplash is offline
Vehicle: 2013 1500 SLT Big Horn 4x4
Color: Black Gold
Rep:177
Whiplash has a spectacular aura aboutWhiplash has a spectacular aura about
i had an issue with the center bracket at first, but after a day or two decided to go at it again.
i loosened up the front and rear one almost all the way out...removed the metal piece from the center bracket grommet to get the bolt lined up and re-inserted it as i was tightening the bolt. once it was in i re-tightened the front and rear brackets
i think i'm going to gasket the window, even after re-adjusting it i can't get it to sit flat
S&B did offer to send me a new window (A1+ customer support!!!!) but i'd rather have a fuller seal so...
MODS: Magnaflow 16869 cat-back - S&B CAI - BakFlipG2 - Bilstein 5100s F/B - AirLift 1000 - BackRack - FT-857D/ATAS-120
next: Rims 'n rubber - That'll be it, too many electrical risks involved to go furthur
Old 08-27-2013, 07:56 PM
Whiplash's Avatar
Color: Black Gold
Rep:177
also, i've noticed a couple of pics now, and heard a few comments regarding this....
i'm seeing everyones air sensor being clip up....mine was clip down. i re-installed it that way and haven't seen any issues, just one of those weird things i guess??
Old 08-27-2013, 09:21 PM
Ramops Ramops is offline
Vehicle: 2013 Dodge ram 1500
Rep:15
Ramops is on a distinguished road
I have the same issue couldn't get my to seat right. What kind of gasket you planning on using. The engraving wasn't do great either
Old 08-27-2013, 09:35 PM
Grubrunner's Avatar
Rep:3883
I too have never been thrilled with the way the top plexiglass cover sits, truth be told. Sure, it does the job, but cosmetically, it can be a little better fitting.
So I'm doing something about it after several months.....
I'm getting my buddy to re-do it in a couple of weeks. I'm taking it to his body shop where he'll cut out a new template that sits damn-near flush with about 2MM lip. I'm then taking that to another friend who works with persplex/plexiglass and having him router cut it perfectly. I'm then having him cut a second one which I will send to S&B Filters so they can use it as a [perfect fitting] template from here on.
I'm then taking my one home and polishing up the routed edges for a smooth finish.
I should have it completed within the next couple of weeks or so. Just a little tough right now as we are moving house.
Grub out!
Old 08-27-2013, 11:25 PM
2002kasner 2002kasner is offline
Vehicle: 2013 Ram
2002kasner is on a distinguished road
Are you affiliated with s&b?
