Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Accessories - Dodge Ram Parts - Dodge Ram Performance - Registered Vendors! > Total Load Control - Dodge Ram Air Suspension
Total Load Control - Dodge Ram Air Suspension TLC™ is the patented air suspension that solves the problems hauling or towing heavy loads with coil springs. No modification required; keep the coil springs. Fits all 2009-16 RAM 1500 including Ecodiesel and 2014-16 RAM 2500! Spacers available for most 4" and 6" lift kits for RAM 1500
TLC also makes units for 02-13 RAM 2500 & 02-16 RAM 3500 with leaf springs.
TLC adds over 5,000 lbs of lifting power to level any load or tow with the largest air springs on any full-size pickup – 9” Goodyear® dual bellows. Your truck will be safer, handle better and go faster around curves. TLC doesn’t interfere with the factory ride. You’ve never experienced the power of air bags until you try Total Load Control™.
Easy to install; no drilling; fits leveled & body lifted trucks.
We introduced TLC on the Z and have many happy Z customers. Get Total Load Control Today !
tonneaucovered.com
Old 04-11-2013, 09:20 PM
tkjones2 tkjones2 is offline
Vehicle: 2012 ram 1500 outdoorsman
Trim Level: Outdoorsman
tkjones2 is on a distinguished road
Default a few newb questions about TLC and Wireless 1
Just picked up my 2012 ram 1500, i will be towing some with it anywhere from 3000-9000 pounds, this will be on occasion not all the time. Anyway after doing some reading it looks like the TLC product will be one of the 1st addons, and planning on the air lift wireless 1 controller. I will be contacting TLC in the next cpl days to try to speak to John about it.
for those with this setup did anyone mount the compressor under the back seat or in the rear floorboard storage compartments ??
Does the standard compressor seem to be adequate ?? or did you wish you had gotten the Heavy duty compressor??
Also with the standard compressor is there a way to "T" off of it to use the compressor for other things ie a motorcycle tire, car tire, air bed, etc ???
thanks in advance all
Troy.....ride/drive safe
2012 Ram 1500 Outdoorsman, Mineral Grey, 5.7 4x4 3.92
Old 04-11-2013, 09:42 PM
Rep:2101
I have the WirelessOne compressor for my airlift 1000's. I mounted it above the spare tire on the brace for it. It stays almost completely dry up there and I wanted to keep stuff outside of my cab. It made it really easy for routing the air lines and wiring as well. Then all I had to do us run the power wire up the frame of the truck for power. I've had it on there for a couple months and haven't had any problems.
Old 04-14-2013, 08:38 AM
Brandon:
thanks for the reply, ill check out that spot, how is your system working for you??
Old 04-14-2013, 12:57 PM
Rep:2101
Originally Posted by tkjones2 View Post
Brandon:
So far I've only used it once to haul a flat deck car trailer about 50 miles. Based on that trip I loved them though. Kept the truck nice and level and the ride was a lot nicer. Without them I noticed that the truck bounced a lot going down the highway (I don't have a WD hitch). With the bags in it kept the truck a lot more stable. It's really nice having the wireless compressor system on it too to raise or lower the pressure on the fly based on how the truck feels.
Old 04-17-2013, 01:20 PM
TLC John's Avatar
TLC John TLC John is offline
Vehicle: 2006 Dodge RAM
Rep:17
TLC John is on a distinguished road
Default TLC v. AirLift 1000
TK,
Just want to mention that TLC has over 5X the lifting/leveling power of the AL1000.
Seems every week we get orders for TLC from people who have had the AL1000.
Since your RAM is the best truck out there, why not go with the best air suspension.
TLC will make your RAM really work like a truck!
John
Total Load Control™
Revolutionary Air Suspension for RAM 1500 2500 3500 4500 5500
Level Every Load with TotalLoadControl.com
Old 05-30-2013, 10:16 PM
barndog89 barndog89 is offline
Vehicle: 2011 Dodge Ram
Color: Rugged Brown Pearl / Light Pebble Beige
barndog89 is on a distinguished road
I purchased the TLC air bags and the wireless 1 air compressor. I installed the airbags last Friday night. It was extremely easy, it took longer to keep rereading the instructions to be sure I wasn't missing something then it did to actually do the install. The air compressor however did not get installed because I could not find a place I liked to install it. After spending the weekend pondering what to do, I decided to build a bracket to fit. As of today the bracket is built and painted. I am hoping to install it tomorrow evening, if it doesn't get done I will not have another opportunity until next weekend. The bracket will mount under the hood towards the front of the truck. This is my first reply and I haven't figured out how to post yet, but I'll answer any question I can to help.
Mike
Old 06-02-2013, 04:47 PM
Asur Asur is offline
Vehicle: .
Rep:4373
I installed my wireless 1 under the passenger rear seat.
Old 06-06-2013, 08:48 PM
TLC John's Avatar
Rep:17
Default WirelessOne Install Instructions
Here is a link to installation instructions for WirelessOne.
http://catalograck.com/imgVD/AIL/MN-751_25870.pdf
Total Load Control™
Old 08-28-2013, 07:38 PM
Connman67 Connman67 is offline
Vehicle: 2011 Dodge Ram 1500
Trim Level: Outdoorsman SLT
Color: black/gray
Connman67 is on a distinguished road
Have had mine for six Months now. I love them, i haul a 27' 5th wheel about 7000 LB.
No more bounce when i go over bumps when hauling. It acts as if you are not pulling anything. There is no more sag either, sits level. You will love how it responds to hauling.
