Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - General Discussion > 2014 Dodge Ram Forum
2014 Dodge Ram Forum For specific discussion of the 2014 Dodge Ram!
Old 08-13-2013, 03:37 PM
geeky geeky is offline
Vehicle: 2013 Dodge Ram
geeky is on a distinguished road
Default Info on towing?
I have a 2013 Laramie 4x4 5.7L. I am going to be towing a TT weighing 5181 Dry. I have used the calculator online (ramtrucks.com) and it looks completely doable. (Assuming i have 2 passengers 1 is a three year old. and 100 lbs for a WDH.)
Some folks on the Rv forums are thinking I am going to be very close to my tow rating.. am I missing something?
Old 08-13-2013, 04:06 PM
crabjoe crabjoe is offline
Vehicle: 2014 Ram 3500
Color: Maximum Steel Matallic
Rep:62
crabjoe will become famous soon enough
No idea what that truck is rated to pull, but dry weight is with nothing in it. When you start adding stuff, for a trip, the weight adds up real fast....
If I were you, I'd look at what the gross weight the trailer is rated for and use that number vs it's dry weight.
Old 08-13-2013, 04:18 PM
Hermes1 Hermes1 is offline
Vehicle: 2015 Big Horn 3500 Cummins TD
Rep:2559
Yes, dry weights are meaningless. Find out what the gross vehicle weight rating (GVWR) of the trailer. The door jam label on your truck will give you the tow rating of your specific truck.
Old 08-13-2013, 06:21 PM
Ramzaq Ramzaq is offline
Vehicle: 2009 Ram CC 4X4
Trim Level: SLT, Big Horn
Color: Black Pearl coat
Rep:233
Ramzaq has a spectacular aura aboutRamzaq has a spectacular aura aboutRamzaq has a spectacular aura about
We need more info on your truck especially what rear end ratio.
My truck is rated to pull 8500 lbs and my payload is rated at 1436 lbs (CC, 4x4, Hemi, 3.55 rear)
Figure a tongue weight near 510 lbs, about 10%, subtract that from your payload. In my case that would leave 926 lbs. That is how much weight you would have left for everything else.
So you will be close to the payload limit if your truck is similar to mine when fully loaded.
Sad, but you run out of payload before you reach your tow limit. It is not just Ram, it is the same with all the light duty pickups.
Old 08-13-2013, 07:09 PM
Rep:62
I'm not sure what your setup is like but take a look at this thread... The guy bought a 28 TT and ended up trading it in on something smaller... The 1500 just wasn't enough for the trailer...
http://www.ramforumz.com/showthread.php?t=136755
Old 08-13-2013, 08:50 PM
Parkersdad Parkersdad is offline
Vehicle: 2013 Dodge Ram 2500
Color: Mineral
Rep:21
Parkersdad is on a distinguished road
This is the exact reason I just bought a three-quarter ton Ram.
Old 08-13-2013, 08:56 PM
Stump3r's Avatar
Stump3r Stump3r is offline
Rep:1266
+1 to what Ramzaq said. Sadly I have a similar issue with mine in that I run out of payload long before I run out of towing capacity.
Big Red my old 2011 Sport
Old 08-13-2013, 10:31 PM
gwilburn's Avatar
gwilburn gwilburn is offline
Vehicle: 2014 Ram 1500 Crew 4x4
Color: Maximum Steel Metallic
Rep:108
gwilburn will become famous soon enoughgwilburn will become famous soon enough
Really??? Assuming you don't have the 3.21 rear end, you are WAY under the limit. 3.55s are rated for 8700 and 3.92s for 10,100. I wouldn't pull anything over 7500 or so w/out load levelers
FWIW, I pull a 20' enclosed trailer (about 5000 lbs) + wind drag, with a cab full of guys and a bed full of gear 800+ miles at 75 mph.
Old 08-14-2013, 02:01 AM
randomid25's Avatar
randomid25 randomid25 is offline
Vehicle: 2010 Ram 2500
Color: Inferno Red
Rep:28
randomid25 is on a distinguished road
Gross combined weight rating (GCWR) is the most important. This is what your truck is rated for total. This means the weight of the truck, passengers, cargo, fuel, trailer, trailer cargo, EVERYTHING. It's also the easiest to check as you can just pull in to a truck stop and scale your truck and trailer.
Another rating you'll wanna pay attention to is the gross axle weight rating (GAWR). If you scale your truck and trailer, It will tell you how much weight you have on each axle. This way you can tell if you need to shift weight, for example, from the bed of the truck to the trailer, or vice versa.
You'll also be able to tell if you are exceeding gross vehicle weight rating (GVWR), which the total weight capacity of your truck, fuel, passengers, and cargo not counting trailer weight, by adding the front and rear truck axle weights together.
Old 08-14-2013, 07:09 AM
exilepa exilepa is offline
Vehicle: 2014 Longorn 1500
Trim Level: Longhorn
Rep:15
exilepa is on a distinguished road
In reality, the truck will be able to pull much more than it's rate for. The key; being able to stop that load safely and accelerate quick enough (as quick as you can with a trailer) to avoid danger. The rating is there for the manufacturer to cover themself if you do something stupid like tow 8500lbs with the 3.21 rear end. Some of the stuff I've seen people pulling down the highway with Trailblazers and smaller SUVs is downright frightening!
