wet floorboard! help - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Diesel Forums!
Dodge Caliber
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Place your Ad Here!
Old 08-13-2013, 07:00 PM
Dougie91 Dougie91 is offline
Vehicle: 1998 Dodge Ram
Trim Level: W/T
Dougie91 is on a distinguished road
Default wet floorboard! help
whenn i run my a/c the floor board is getting wet. the tube is clear, i even shot cleaner into the system, what could it be?
Old 08-13-2013, 08:02 PM
RogerRamJet's Avatar
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
Is condensation running off the evaporator and in to the cab somewhere?
Old 08-13-2013, 09:47 PM
Revel Performance's Avatar
REVEL PERFORMANCE
Vehicle: MOPAR
Rep:931
Heater core leaking?
sales@revelperformance.com
Old 08-13-2013, 11:29 PM
Rep:2968
I thought that at first, too. But coolant is always going through the heater core and the OP said it only occurs when the a/c is on. Doesn't mean it's not the heater core though.
Old 08-15-2013, 05:53 PM
cadams155 cadams155 is offline
Vehicle: 2000
Trim Level: SLT Laramie
Color: Green
cadams155 is on a distinguished road
This was a 4 part problem on my truck.
1) There are 3 main passages through the firewall to the cab that were leaking on my truck.
  • Heater core passage
  • AC line passage (condensation can and will drip down the firewall and into the cab) - i'm still considering an insulating wrap
  • AC drain line passage.
I sealed all 3 with silicone and foam.
2) My heater core was completely clogged (along with the rest of my cooling system) and did leak into the cab
3) The drain line at the bottom of the firewall is letting water drain back into the cab. Get a 3-4 inch piece of 5/8 heater hose from autozone and a hose clamp and put it on the drain line. This will prevent water from flowing out, running along the bottom of the drain outlet tube, and back towards the firewall.
4) My 3rd tail light was leaking. $3 roll of foam from lowes and that was fixed.
