Old 08-13-2013, 11:51 PM
dodgehemi0 dodgehemi0 is offline
Vehicle: 2013 Sport Crew
Rep:26
dodgehemi0 is on a distinguished road
Default weird problem with uconnect?
So, I was on the phone connected through the truck so I get home and turn the truck off. Phone is still connected to the truck which is normal. Then I go to touch the transfer button on the screen. Normal thing happens it transfers the call to my phone, so I open the door and the screen and audio should shut off right? well it would not. I started the truck and turned it off still the screen and audio would not shut off. then I started the truck and put it in gear moved it a little and still the screen and audio would not turn off after opening the doors. First time it has done this anyone else have this problem? The audio and screen always shut off after I open the door if the truck is off.
Old 08-14-2013, 12:13 AM
reboot04 reboot04 is offline
Vehicle: 2013 Dodge RAM 1500
Color: White w/ Chrome
reboot04 is on a distinguished road
I had exactly the same thing happen to me. So I hung up the phone and it immediately shut down. Somehow thru a transfer it still wants to stay in the middle. Now I just do the transfer from the phone side and its not an issue. Was weird though.
Old 08-14-2013, 01:13 AM
edge35's Avatar
edge35 edge35 is offline
Trim Level: Laramie Longhorn 4x4
Rep:70
edge35 will become famous soon enough
Ah, you must have the NSA Edition of Uconnect.
2013 Laramie Longhorn 4x4
6 speed (although the 65RFE is really a 5 speed), 3.55, air suspension, anti-spin, 20" Goodyear Wrangler SRA tires (aka crap), sunroof, Bakflip Fibermax & BakBox, bed extender, 8.4AN, black/cattle tan interior
Old 08-14-2013, 02:19 AM
bigbody's Avatar
bigbody bigbody is offline
Vehicle: 2013 Ram 1500 Laramie
Color: Black/gray
bigbody is on a distinguished road
Your radio will not shut off till the phone call has ended it's not a problem with the radio all Uconnect systems do that, the one in my 2010 and the one in my wife's 2012 Durango does the same thing
2013 RAM 1500 Laramie, sunroof, 3:55gears, undercover se, avs in channel, 30% tint all around
Old 08-14-2013, 08:30 AM
Rep:26
Thanks guys ya I guess I have the nsa version haha
Old 08-14-2013, 06:47 PM
plumcrazy73's Avatar
plumcrazy73 plumcrazy73 is offline
Vehicle: 2013 Ram 1500 2WD Crew Cab
Trim Level: SLT w/Big Horn EQ GP
Color: True Blue Pearl
Rep:119
plumcrazy73 will become famous soon enoughplumcrazy73 will become famous soon enough
The NSA was still listening in and was not done recording yet!
Old 08-15-2013, 08:38 AM
xsdbs xsdbs is offline
Vehicle: green flying carpet
Trim Level: upper and lower
Rep:73
xsdbs will become famous soon enough
Did you transfer the call from the phone or from the radio / Uconnect voice command?
If you do it from the phone itself, the BT Hands Free profile is still connected and this will happen. However if you press the Uconnect voice button and say "transfer call", the call will be transferred to the phone and you'll see the radio go out of the Hands Free mode and into the radio mode. When you turn the key off, now the radio will shut down completely when you get out of the vehicle.
Old 08-20-2013, 12:12 PM
firemarshallvin's Avatar
firemarshallvin firemarshallvin is offline
Vehicle: 2013
Color: Black Gold Pearl
firemarshallvin is on a distinguished road
Same here, will have to try the above suggested method of transferring I guess. I was rather annoying to have to hang up on the caller just to get the radio to shut off.
2013 RAM 1500 Laramie Longhorn - Black Gold Pearl with all the trimmings. HEMI, 3.92, 8-Speed and Air Suspension
Add-ons:
14" Magnaflow, BAK FiberMax Tonneau, Misc Whelen Emergency Lights and Switchpak, 275/60R20 - BFG T/A KO2
Old 08-20-2013, 05:54 PM
KJ48 KJ48 is offline
Vehicle: 2013 1500 Ram CC
Color: Mineral Gray
Rep:117
KJ48 will become famous soon enoughKJ48 will become famous soon enough
My '10 and '12 were the same way, if you transferred the call via the audio source on the iphone the radio would not shut off until you hung up.
I'll have to try the transfer on the '13 on the radio screen and see what happens.
Old 08-21-2013, 08:58 AM
Vehicle: 2013
So I just tried this method a few minutes ago as I got a call on the way into work. I didn't want to walk away from the rig or hang up on the caller either. I turned off the rig first, and nothing, radio stayed on and connected. Then I transferred the call via the radio to my phone (iphone 5 FYI). The radio remained active, so i opened and closed the door thinking that maybe it was still in the "on delay", and still no change. SO I stayed on the phone (handset) until it ended. As soon as the call was ended on my phone the radio shut down. Oh well, guess next time I will try walking away and just coming back after the call to confirm it shut down.
Add-ons:
