Old 08-14-2013, 10:46 AM
Carvermitch's Avatar
Carvermitch Carvermitch is offline
Vehicle: 2002 Dodge Ram 1500 quad
Color: Garnet Red metelic
Rep:12
Carvermitch is on a distinguished road
Default water behind dash somewhere
This morning after heavy rain, I got into my truck and heard a sound of sloshing water somewhere under the windshield in front of me.
I bounced around and heard it sloshing but there was no water leak inside the cab.
I was parked on a slight uphill. I started the truck and moved back slightly then braked a few times and the noise got les and less. By the time I got about a mile down the road it had all gone.
I checked all fluids in the engine bay were correct and no signof any leaks anywhere.
My only thought was water drains blocked in the air intake vents in front of the windshield.
Are there drains there that could be blocked and if so where are they please?
Thanks
Paul
Old 08-14-2013, 01:35 PM
Trim Level: sport
Color: green
Rep:677
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
are you sure it wasn't water sloshing around in the bed and you thought the sound was coming from the windshield.
Old 08-14-2013, 02:14 PM
Rep:12
No, the bed is covered and it was certainly in the front. I just went out and ran the hose over the air vent intake at the base of the windshield and got the same sound so its in there.
There must be a drain blocked but where is it.
Old 08-14-2013, 05:02 PM
Chunkem's Avatar
Chunkem Chunkem is offline
"Just living the dream"
Trim Level: Longhorn Rambox
Rep:1637
Yep it sounds like you had a blocked drain....Next time you hear that(hopefully there is no next time) I would stop and have a look....Good news...No water in the cab......
Old 08-14-2013, 06:31 PM
battlerattle's Avatar
Vehicle: 2011 Power Wagon
Rep:275
Water will pool in the cowl area just outside the window (though it does sound as if it is inside) during a rain. If it does its cause your drains are plugged. Just run a light wire or long pipe cleaner down them. They are on the cowl (plastic piece under windshield wiper) to either side....small hole.
Spyntec Hubs, 35" Toyo AT II, Synergy Steering Brace, Fox 2.0 IPF. BullyDog Tuner, Katskinz Leather........................
Old 08-14-2013, 08:56 PM
Trim Level: sport
Color: green
Rep:677
battlerattle beat me to draining the cowl if plugged.
Old 08-15-2013, 09:33 AM
Rep:12
Thanks guys
I will check out this morning and run the hose through when I have done it to make sure.
Thanks for all the help and advice - this is a great forum.
Regards
Paul
