Old 08-14-2013, 02:38 PM
Kamanhart's Avatar
Kamanhart Kamanhart is offline
Man Up And Cam Up
Vehicle: 2005 Dodge Ram 1500
Rep:1045
Kamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud of
Default OBX headers en route
hello all i just purchased a set of OBX headers for my 2005 dodge ram, pretty excited about it... my question is for header bolts i hear either stage 8 lockers or arp bolts. what is a general consensus of the better choice?
Old 08-19-2013, 10:32 PM
moparmike07's Avatar
moparmike07 moparmike07 is offline
Vehicle: 07 dodge ram 1500
Trim Level: st
Color: silver
Rep:68
moparmike07 will become famous soon enough
Stage 8 bolts best
2007 dodge ram 1500 quad cab 4x4 5 percent tint all around 35 percent windshield, ported tb, diablo sport, arh headers, magnaflow dual exhaust, magnaflow y pipe, krc210x cam,nitrous,CNC ported head. 4.56 motive
Old 08-30-2013, 09:21 AM
Kamanhart's Avatar
Man Up And Cam Up
Rep:1045
Well i got the header in and while taking out the manifolds i found the annoy broken manifold bolt that was causing the leak. The quality of build on the headers was about 6 times better than i expected everything was was excellently tig welded together and fit up perfectly to the truck. there was 2 low points for this headers though, i think they sent me the wrong cross over pipe that run from the drivers side header behind the transfer case, it was 2 inches short to get around the transfer case so i had to cut it and weld in a 2 inch stainless extension, also on that same pipe the rear o2 sensor is is point towards the outside of the exhaust making it really weird angle to get at, but i cut the pipe spun it around to the correct position and every thing is working beautifully.
Old 08-30-2013, 09:27 AM
TonyG-'s Avatar
TonyG- TonyG- is offline
Vehicle: 2010 Ram 1500
Rep:192
TonyG- has a spectacular aura aboutTonyG- has a spectacular aura about
Pipes look great! Feel any difference?
Old 08-30-2013, 09:54 AM
Kamanhart's Avatar
Man Up And Cam Up
Rep:1045
yes sir, the obx is a 2.5 inch collector and i think it helped keep the torque band in the lower rpms because it is now a monster off the line.
