Old 08-14-2013, 02:31 PM
emwest emwest is offline
Vehicle: 1997 Dodge Ram Van 3500
emwest is on a distinguished road
Default help- 5.2 still has misfire on #8 after plenum fix
1997 Dodge Ram Van 3500, 5.2, only 70k miles, engine strong. On a recent trip the plenum gasket failed, it started burning oil, and fouled number 8. New plug would immediately foul. Drove it home several hundred miles on 7 cylinders, had no choice. Fixed the plenum with the Hughes kit. Engine is happier now but still has a miss on cylinder 8. New plug fouls. Does anyone know how I can "de-foul" this cylinder? Dealer sold us some stuff to spray into the engine, this did not fix it. I really don't want to pull the head. I guess I'll check compression next. Any ideas from anyone? Thanks.
Old 08-14-2013, 10:34 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
First thing I'd do would be to run a bottle of Seafoam through the fuel system, and another in the intake.
Old 09-23-2013, 09:35 AM
cdetterer's Avatar
cdetterer cdetterer is offline
Vehicle: 2006 Dodge Ram 3500
Trim Level: SLT Big Horn
Color: Maroon
Rep:42
cdetterer is on a distinguished road
Do you just dump the SeaFoam straight into the throttle body?
Old 09-23-2013, 03:51 PM
Rep:85
In the tank? Yes. Intake? No. Pour some, and let run. Pour some more. Let run. Do this over several minutes. If it continues, you may have a hardware problem.
Old 09-23-2013, 04:27 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Sea-Foam now comes in a user friendly spray can that can easily be sprayed directly into the throttle body. Contact your local parts supplier for availability.
And now back to you Gen One...
Old 09-23-2013, 06:09 PM
cdetterer's Avatar
Color: Maroon
Rep:42
Ok I have heard of guys pouring the seafoam straight into the PCV valve line right into the intake.
The spray seems like a very convenient idea
Old 09-23-2013, 08:41 PM
Rep:85
Then just go out and romp on it. Blow the cobwebs out.
Old 10-02-2013, 07:45 PM
namretsud's Avatar
namretsud namretsud is offline
Vehicle: 2007 1500 Mega Cab 4X4 3.73
Color: Inferno Red
Rep:185
namretsud has a spectacular aura aboutnamretsud has a spectacular aura about
It may also be that the oil has caused an issue with the cat. You may also want check/replace the cap and rotor, as the excess oil may have overloaded the electrical circuit to the #8 cylinder.
