Air Suspension Alignment Mode - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Suspension
Old 08-14-2013, 03:55 PM
BigBlueRam BigBlueRam is offline
Vehicle: 2013 Dodge Ram
Trim Level: Laramie Limited
Color: Blue
BigBlueRam is on a distinguished road
Default Air Suspension Alignment Mode
Just had my tires replaced at the local Town Fair Tire and discovered afterwards that there is a selection in the EVIC for wheel alignment. Owner Manual indicates that vehicle must be in alignment mode for wheel alignment.
I never thought to check this, and the tire place did an alignment as part of my install. They likely didn't know either (although the receipt for the alignment shows little adjustment and specifically calls out my model with Air Suspension).
Wonder if this could cause a problem if the mode was not selected?
Old 08-18-2013, 10:45 AM
h2oman's Avatar
h2oman h2oman is offline
Vehicle: 2012 Ram 1500
Trim Level: Express 4X4
Rep:418
Had to edit my comment since I just realized you have a '13 air suspension. My bad.
Old 10-10-2013, 02:14 AM
NeverEnuff NeverEnuff is offline
Vehicle: 2014 Ram
Rep:87
NeverEnuff will become famous soon enough
i was wondering about that myself I almost forgot a couple of times to set my suspension to Jack Mode when I was at Discount Tire. Maybe its called something else because jack mode sounds like a totally different subject. Anyway it would be hard to jack up the truck while the suspension would be trying to level the whole time. I wonder if they align it in entry/exit mode. Aero, or standard? I doubt they would do it in off road 1 or 2. Im guessing alignment is done in standard height.
