Old 08-03-2013, 06:24 PM
Hemi Todd's Avatar
Hemi Todd Hemi Todd is offline
Vehicle: 2012 Dodge Ram 2500
Rep:59
Hemi Todd will become famous soon enough
Default 4.10 vs 4.56
looking to change gear ratio soon. origionally wanted 4.10s but seems only kit i can find is in 4.56. http://www.riversidegear.com/differe...500-4x4-1.html. randys ring and pinion that i have used in past has no gearsets listed for 4th gen front carriers. 4.56 seems just a little low running 35s imo, then again i am in wv so maybe theyre not. so i guess what im asking is anyone know of any other reputable company that offers what im looking for? or can someone with 4.56s tell me what rpm they have (give or take) @ 70 mph? (and yes i tried the search) maybe just me but i cant find anything
Old 08-06-2013, 05:02 AM
SmokeyT SmokeyT is offline
Vehicle: 2010 Ram 1500
SmokeyT is on a distinguished road
I too am trying to decide between 4.10 and 4.56. Subscribing...
Old 08-06-2013, 07:48 AM
Rep:1385
You'll be turning 1846 rpms at 70mph in 6th gear with 35" tires with 4.10s
You'll be turning 2053 rpms at 70mph in 6th gear with 35" tires with 4.56s
Most people tend to get 4.56's but depending on your use 4.10's may be a better choice. A lot of people that drag race have found 3.92s and 4.10s to give better ET's than 4.56s due to the gear ratio spread of the transmission. If it's purely for on or off road use 4.56s will likely feel better.
Old 08-08-2013, 12:58 AM
Cat Daddy's Avatar
Cat Daddy Cat Daddy is offline
Vehicle: 2012 Ram 1500 4X4
Rep:68
Cat Daddy will become famous soon enough
I am somewhat confused ,guys are drop back to the 2011 differential to be able to do gear swap...seams strange that only 4:56 are available , not saying anything about Randys but have you contacted and gear manufactures direct?
20X9 Black XD Hoss with painted caps 275x65x20 NittosTerras,Bilsteins 5100's @ 2.1, .75" in rear,laminx tinted head lights,tinted tail lights & 3rd brake light, S&B,Fastman 84 TB,18' Magnaflow,T1000-hemifever,cabin filter,RECON led cab lights,custom dynamic 60" light bar,tow hooks,debadged ,6" shorty ,painted grill and front and rear emblem , AMP power step ,F1 Bacflip bed cover ,Mopar bed rug kit
Old 08-08-2013, 03:07 PM
Spike Spike is offline
Vehicle: 2013 RAM Big Horn 4x4
Rep:58
Spike will become famous soon enough
Here is my 'real world' experience with several rigs from Jeeps to Trucks.
Take the stock configuration, let's say, for example a 3.55 gear and 33's. Drop 1 ratio per 2" of tire diameter plus 1 ratio for the increased drag from a more aggressive tire and leveling or minor lifting wind drag...so 4:10's. Consider even if you get almost exactly back to the same highway rpm you were running stock, you are still going to need more power and more rpms to maintian the same driveability.
If you had 3.92's, liked them, stepped up 2" in tire size and leveled, then 4:56 would be just about right.
For me, I am running 3.21's and think it is a step too tall with the 8 speed. 3.55's would be about right with the stock tires just under 33's. So, with a planned 6" lift and 37's, I will be looking at two steps lower for the tires and another step for the drag and I get to 4:56 as my closest ratio.
Don't fear the gear.
2.5" RC Lift, 305 R20's, Winch, Softtoper,
K&N, Pop up in tow, German Shepherd co-pilot
Old 08-11-2013, 07:27 PM
Hemi Todd's Avatar
Rep:59
Cat daddy I was curious why as well.maybe something to do with the carrier? Anywaya Just wanted to see what you all thought. I will check other places you spoke of thanks.
Old 08-15-2013, 02:12 PM
Fasthemiram11's Avatar
Fasthemiram11 Fasthemiram11 is offline
Vehicle: 2012 Ram Express
Rep:15
Fasthemiram11 is on a distinguished road
For 2011-13 you have to modify the rear carrier to fit the older style 9.25 4.56's.
modern performance in Orlando does this machining.
2012 SOUTHERN EXPRESS
Had 2011 HEMI EXPRESS 12.4@111
