Old 08-15-2013, 08:51 AM
Nabby Nabby is offline
Vehicle: 1991 Dodge Ram
Trim Level: Unknown
Nabby is on a distinguished road
Default Painting between bed and cab?
I have a 91 D-150 I would like to paint, it's currently a two-tone blue, and while I'd really like to repaint it a charcoal color, I'm not sure what's involved in detaching and sliding the bed back so I can paint the area between bed and cab... do I need any special equipment to move something that big and heavy? How does any other at-home truck painter do it?
Old 08-15-2013, 10:08 AM
battlerattle's Avatar
Vehicle: 2011 Power Wagon
Rep:256
Nope. Its 6 bolts, a few wire connections and you need about 3 good sized friends. The bed only weighs 250-400 lbs depending on length.
Spyntec Hubs, 35" Cooper STT, Synergy Steering Brace, out of money........................
Old 08-15-2013, 08:42 PM
The1 True Outlaw's Avatar
The1 True Outlaw The1 True Outlaw is offline
Rep:62
The1 True Outlaw will become famous soon enough
I can second that. Haven't done it to my Ram but when I painted on the frame on my dakota it was a few bolts and 4 of us lifted it off. All the wiring had connectors that were easy to pop apart. Easiest part of the job.
Old 08-15-2013, 10:18 PM
gcscott's Avatar
gcscott gcscott is offline
Rep:1043
Take out the bed bolts and disconnect the wiring. Use some 2X4s and jack up the bed. Place some 1 1/2" or 2" PVC pipe under the bed and roll it back. Or get some friends if you want to take it all the way off.
Old 08-16-2013, 10:16 PM
will36 will36 is offline
Vehicle: 2010 R/T RAM
Trim Level: R/T
Color: BLUE
Rep:274
will36 is a jewel in the roughwill36 is a jewel in the roughwill36 is a jewel in the rough
just put the rear end on jackstands remove the tires and rear bumper. unbolt it and slide it back a little. I do it all the time. I put a bedside on this week doing the same thing and trimmed in the front of the bed. We usually pull the bed , but we had a shop full this week.
Old 08-16-2013, 10:33 PM
Rep:2657
that is the same method most people use when changing out fuel pumps
you could use a cherry picker or a good size tree limb & a come-a-long or two
Old 08-18-2013, 11:41 AM
Trim Level: Unknown
Are they that easy to just slide? Something one person can do by himself? I keep a small circle of friends, and we're all putting in 60 hours a week at the same factory doing a lot of heavy lifting, so getting any of them together to do anything physical in our off time is downright impossible, so I have to make a one man job of this.
Old 08-18-2013, 07:01 PM
Trim Level: R/T
Color: BLUE
Rep:274
I do it myself all the time. One side... I think the drivers side has a plastic line up spike. just lift it up a little and slide it back. I have put a new bedside on a truck, painted it and sent it home in a day. There will be plenty of room.
