Old 08-15-2013, 12:38 AM
Gecko's Avatar
Gecko Gecko is offline
Vehicle: 2004 Quad Cab
Trim Level: SLT 4x4
Rep:221
Gecko has a spectacular aura aboutGecko has a spectacular aura aboutGecko has a spectacular aura about
Default What should I do?
So my CEL came on today. I checked the code and its my EGR valve. Again. This is the 3rd of 4th time since last August that the code has come up (I've lost count at this point). I have changed the EGR valve every other time so I am starting to think that maybe its not the valve but something in the piping leading to it.
I'm not really sure what my options are right now. I know I can get an EGR valve delete kit and then I would have to get another custom tune to tune out the EGR valve which isn't out of the equation.
But, I'm thinking maybe I just need to clean everything and that might do the trick as well. Would running Seafoam through the intake and in the fuel tank, removing the EGR and cleaning the piping going to it, as well as, maybe even removing the throttle body and cleaning that, possibly solve the problem?
I feel like these are my only 2 options so I don't have to keep dealing with this every few months. What do you guys think?
Supercharged, cammed, other things too!
Old 08-16-2013, 03:22 AM
RogerRamJet's Avatar
I do it because I can!
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
I think Seafoam is a great option. And although it may not fix the EGR issue, it won't hurt it either.
Old 08-16-2013, 02:58 PM
Gecko's Avatar
Trim Level: SLT 4x4
Rep:221
I was planning on the seafoam to begin with. I need to do my spark plugs so I was going to do it then but now I guess I might do it sooner.
I'm still trying to figure out the EGR problem though
Old 08-17-2013, 03:45 PM
20hemi10 20hemi10 is offline
Vehicle: 2014 Ram 1500 4x4
Trim Level: Outdoorsman
Rep:14
20hemi10 is on a distinguished road
I just looked it up on Dealerconnect and it shows a PCM flash that should take care of your problem.
THIS BULLETIN IS BEING PROVIDED IN ADVANCE. THE SOFTWARE FOR
DR VEHICLES WILL BE AVAILABLE ON TechCONNECT MARCH 2, 2004.
THE SOFTWARE FOR HB VEHICLES WILL BE AVAILABLE ON StarSCAN™
SOFTWARE UPDATE CD RELEASE 4.06, MARCH 15, 2004.
SUBJECT:
Flash: MIL Illumination Diagnostic Trouble Codes (DTC’s) P0403, P0404, P0405, P0406
OVERVIEW:
This bulletin involves selectively erasing and reprogramming the Powertrain
Control Module (PCM) with new software.
MODELS:
2004 (DR) Ram Truck
2004 (HB) Durango
NOTE: This bulletin applies to DR and HB vehicles equipped with a 5.7L engine
(sales code EZA) built on or before February 29, 2004 (MDH 0229XX).
SYMPTOM/CONDITION:
The vehicle operator may experience a MIL illumination. Further diagnosis may determine
that the MIL was caused by one or more of the following DTC’s:
P0403-EGR CONTROL CIRCUIT
P0404-EGR POSITION SENSOR PERFORMANCE
P0405-EGR POSITION SENSOR LOW
P0406-EGR POSITION SENSOR HIGH
2014 Ram 1500 Outdoorsman 4x4 5.7L
Old 08-19-2013, 02:02 AM
Gecko's Avatar
Trim Level: SLT 4x4
Rep:221
If I have them do this will it mess with my custom tune? I don't want to mess with it if the tune is gonna get screwed up or something.
I cleared it the other day and it hasn't come back since. It's also not really a code I am too worried about just more annoyed with than anything
Old 08-20-2013, 12:02 AM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
going to the dealer for a PCM flash will just over write your custom tune. You could try to explain the problem to your tuner and ask them to take a look.
