Old 08-15-2013, 09:51 AM
Nabby Nabby is offline
Vehicle: 1991 Dodge Ram
Trim Level: Unknown
Color: Blue
Nabby is on a distinguished road
Default Painting between bed and cab?
I have a 91 D-150 I would like to paint, it's currently a two-tone blue, and while I'd really like to repaint it a charcoal color, I'm not sure what's involved in detaching and sliding the bed back so I can paint the area between bed and cab... do I need any special equipment to move something that big and heavy? How does any other at-home truck painter do it?
Old 08-15-2013, 11:08 AM
battlerattle's Avatar
Vehicle: 2011 Power Wagon
Rep:256
Nope. Its 6 bolts, a few wire connections and you need about 3 good sized friends. The bed only weighs 250-400 lbs depending on length.
Spyntec Hubs, 35" Cooper STT, Synergy Steering Brace, out of money........................
Old 08-15-2013, 09:42 PM
The1 True Outlaw's Avatar
The1 True Outlaw The1 True Outlaw is offline
Rep:62
The1 True Outlaw will become famous soon enough
I can second that. Haven't done it to my Ram but when I painted on the frame on my dakota it was a few bolts and 4 of us lifted it off. All the wiring had connectors that were easy to pop apart. Easiest part of the job.
Old 08-15-2013, 11:18 PM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
Take out the bed bolts and disconnect the wiring. Use some 2X4s and jack up the bed. Place some 1 1/2" or 2" PVC pipe under the bed and roll it back. Or get some friends if you want to take it all the way off.
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 08-16-2013, 11:16 PM
will36 will36 is offline
Vehicle: 2010 R/T RAM
Trim Level: R/T
Color: BLUE
Rep:274
will36 is a jewel in the roughwill36 is a jewel in the roughwill36 is a jewel in the rough
just put the rear end on jackstands remove the tires and rear bumper. unbolt it and slide it back a little. I do it all the time. I put a bedside on this week doing the same thing and trimmed in the front of the bed. We usually pull the bed , but we had a shop full this week.
Old 08-16-2013, 11:33 PM
Rep:2616
that is the same method most people use when changing out fuel pumps
you could use a cherry picker or a good size tree limb & a come-a-long or two
Old 08-18-2013, 12:41 PM
Trim Level: Unknown
Color: Blue
Are they that easy to just slide? Something one person can do by himself? I keep a small circle of friends, and we're all putting in 60 hours a week at the same factory doing a lot of heavy lifting, so getting any of them together to do anything physical in our off time is downright impossible, so I have to make a one man job of this.
Old 08-18-2013, 08:01 PM
Trim Level: R/T
Color: BLUE
Rep:274
I do it myself all the time. One side... I think the drivers side has a plastic line up spike. just lift it up a little and slide it back. I have put a new bedside on a truck, painted it and sent it home in a day. There will be plenty of room.
