when should i do tire rotation? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 08-15-2013, 02:12 PM
longhorn2012's Avatar
longhorn2012 longhorn2012 is offline
Vehicle: 2012 dodge ram longhorn
Rep:39
longhorn2012 is on a distinguished road
Exclamation when should i do tire rotation?
hey Guys . according to the manual a tire rotation on my truck should be 13,000KM 9000 Miles. im at 13,000 Kilometers . should i rotate or wait more KM
when should it be done?
Old 08-15-2013, 02:47 PM
markjr's Avatar
markjr markjr is offline
Vehicle: 2012 ram
Trim Level: Big Horn 4X4
Rep:29
markjr is on a distinguished road
I do mine every 2nd oil change. That's 6,000 miles for me. When your looking at $800 minimum for a set, I wouldn't go as far as the manual. Just like oil changes. If your constant highway use, you go longer, but short trips with traffic, the store and just to ride to town, you change it sooner. Idle time is harder than cruising. That's just me.
Old 08-15-2013, 02:53 PM
Buellrider's Avatar
Buellrider Buellrider is offline
Vehicle: 2012 ram 1500 R/T
Trim Level: R/t
Color: Wht
Rep:145
Buellrider will become famous soon enoughBuellrider will become famous soon enough
Depends on driving habits... If I've done a few burnouts I might rotate mine every 5k or if I've done a bunch of burnouts maybe less.
2012 R/T
Old 08-15-2013, 09:49 PM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
Depends on how you drive. For a 4X4 look to see if your tires are cupping in the front from city driving. If so than rotate them. If you go by mileage from highway driving, 3000 to 5000 miles between rotating is good. Good tires cost big $$$.
Greg
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 08-15-2013, 10:08 PM
Rep:2929
when you get your tires rotated
ask what the rotation method is
most dealerships just move the back tires to the front & front tires to the back
the right side tires are always on the right side
that is the wrong way to do a rotation
if you do it that way, your right rear tire is your traction tire & if you were to move it to the front & the front end is slightly out of alignment
you will always wonder why you always have to replace the right side, long before the left sides are due
you have to use an X pattern with a variation
most of us have a Temporary Spare Tire, so it is never used,
that is another thing, most places never check your spare tires air pressure
my spare was down to 28 PSI, it is a good thing to check it for yourself
if your tires do NOT have a directional arrow on them
use a variation of the X pattern
http://www.tirerack.com/tires/tirete....jsp?techid=43
Old 08-16-2013, 12:11 AM
pstreifel's Avatar
pstreifel pstreifel is offline
Vehicle: 2012 Dodge Ram 1500
Rep:34
pstreifel is on a distinguished road
Actually GTyankee the X pattern method is incorrect according to our truck manuals it says that you put the back tires up front (driver side to driver side etc.) then cross the fronts to the back (driver front to pass rear)
Lift 'em high because fat girls can't climb!
Old 08-16-2013, 08:27 AM
Excoastie's Avatar
Vehicle: 2016 Jeep Wrangler
Trim Level: Rubicon Hard Rock
Color: Hydro Blue
Rep:1358
I think the best answer to the OP question is what ever you feel most comfortable with.
Personally I will be getting mine rotated every time I do an oil change (5K miles) due to the fact that when I bought new tires at the beginning of the year they came with lifetime free rotation....
Exco
Bill
Old 08-16-2013, 08:58 AM
Grubrunner's Avatar
Rep:3883
I've always stuck with 8-10K rule on tire rotations, regardless of the tires, driving habits or whatever else.
Grub out!
Old 08-16-2013, 09:09 AM
Kcbigbadram's Avatar
Vehicle: 2007 1500
Trim Level: Big horn
Color: Inferno red
Rep:503
I always do mine around 5-6000 miles.
Old 08-16-2013, 10:37 AM
davidgcet davidgcet is offline
Vehicle: 2012 Ram 1500
Rep:32
davidgcet is on a distinguished road
i do mine nearly every oil change since the tire place i use does it for free for good customers. From April 1st to mid May i had my oil changed 4x and tires rotated 3x, yeah i was putting miles on the truck with trips from MS to WY/NE/IA every week for work.
On my wife's truck we rotate them every other oil change simply because she does nto think about it when dropping the truck off.
