Old 08-15-2013, 03:32 PM
BlackDropEffect BlackDropEffect is offline
Vehicle: 2012 Ram 1500 Express
Rep:25
BlackDropEffect is on a distinguished road
Default Low tire IDIOT LIGHT!
in my 2012 ram 1500 express single cab, a yellow/ orange low tire indicator in the instrument cluster come on every time i start the truck. even after a service from both the dealer or an independent shop. I know they check the tire pressure, but the light keeps coming on. is there a way to unplug a fuse or something to keep the light off? or any other suggestions that's not tape over the light?
Old 08-15-2013, 03:34 PM
Arth's Avatar
Arth Arth is offline
Color: Mineral Gray Metallic
Rep:2028
Do you have HID's that run all the time?
Also is your PSI set correctly at 35 PSI?
Sorry simple questions to check and see.
Chrome... in moderation.
Old 08-15-2013, 03:38 PM
Rep:25
yea, psi always correct, that is the problem, the warning ligt is on even though the pressure is ok. bone stock and no HID lights i dont know why you would ask that.
Old 08-15-2013, 03:39 PM
Arth's Avatar
Rep:2028
I ask because HID's can effect the operation of the TPMS. I had to ask to be sure.
Old 08-15-2013, 03:49 PM
Rep:25
if it has to do with the lights, there is a weird thing going on with that too....when i hit the door lock from the key fob, the headlights sometimes stay on even though they are supposed to turn off. i have to click the unlock, then lock again to get the lights off when parking.
Old 08-15-2013, 03:54 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
my truck even does that.
Old 08-15-2013, 03:57 PM
Rep:25
so is there a fuse or something i can just "pull" for my damn low tire light?
Old 08-15-2013, 05:30 PM
Autobot Gears Autobot Gears is offline
Vehicle: 2012 Ram
Trim Level: sxt
Color: mineral grey metallic
Rep:38
Autobot Gears is on a distinguished road
Default 2012 Rams are 40 psi, not 35
Old 08-15-2013, 05:40 PM
oldhp's Avatar
oldhp oldhp is offline
Vehicle: 2014 Express 3.6/8 speed auto
Color: WHITE
Rep:902
oldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to behold
Are you out of warranty for some reason? 2012 truck doing this, is a dealer problem.
I run 40psi front, 35psi rear with no problems.
2014 Express 3.6/8 speed/3.55 gears...Work Truck
2012 Equinox 2.4...Wife's Ride
"Life's hard, it's harder if your stupid."
How would you know?
Old 08-15-2013, 05:49 PM
Rep:25
i guess its under warranty, but right after a service at the dealership the light came on. i want it to go away without spending 3hrs or more at the dealer
