Old 08-15-2013, 05:52 PM
Stump3r's Avatar
Stump3r Stump3r is offline
Rep:1266
Originally Posted by BlackDropEffect View Post
i guess its under warranty, but right after a service at the dealership the light came on. i want it to go away without spending 3hrs or more at the dealer
Short term fix would be to bump up your tire pressure and see if the light goes out. Otherwise she is a trip to the dealer.
Big Red my old 2011 Sport
Old 08-15-2013, 11:58 PM
pstreifel's Avatar
pstreifel pstreifel is offline
Vehicle: 2012 Dodge Ram 1500
Rep:34
pstreifel is on a distinguished road
I have the same problem, I do have HIDs but they do not run all the time and this problem has been happening before I installed them. I am not under warranty any longer... any other suggestions?
Lift 'em high because fat girls can't climb!
Old 08-16-2013, 08:42 AM
Gantman's Avatar
Gantman Gantman is offline
Trim Level: Tradesman 4x4
Rep:974
Man, a 2012 out of warranty already? You could test each individual TPMS sensor by use of a tester. That will tell you if your TPMS sensors are bad which I think is the cause for your light.
Old 08-16-2013, 02:57 PM
davem2421 davem2421 is offline
Vehicle: 2012 Ram 1500
Trim Level: ST 4X2 1500 QUAD CAB
Rep:57
davem2421 will become famous soon enough
in my 2012 ram 1500 express single cab, a yellow/ orange low tire indicator in the instrument cluster come on every time i start the truck. even after a service from both the dealer or an independent shop. I know they check the tire pressure, but the light keeps coming on. is there a way to unplug a fuse or something to keep the light off? or any other suggestions that's not tape over the light?
I had this same issue, turns out on the 2012 the standard PSI is 40 , once you are at 40 there is a + / - of 5 psi
if you drop below 35psi the light comes on (in my case the EVIC notified me) once the PSI was brought back upto 40 it went away.
Took the dealer nearly 4 days to figure it out they kept saying that 37 PSI was the correct pressure but that was on the 2011 model and since I dropped below 35 and triggered the warning they never brought it back above 40 to reset the sensor. finally they called Chyrsler, what was really funny is it's listed on the door what the PSI should be
Old 08-16-2013, 03:30 PM
pdrules pdrules is offline
Vehicle: 2012 sport quad
Color: deep cherry red
Rep:-11
pdrules can only hope to improve
amazing...some people just shouldn't drive
Old 08-16-2013, 03:33 PM
Rep:57
Who shouldn't be driving?
Old 08-16-2013, 03:37 PM
pstreifel's Avatar
Rep:34
Ya I bought it used last year and it had 29k miles on it but I got a great deal so I cant complain. I talked to the dealership the other day about testing it and they said that it is a radio signal so there is no way to use a fluke meter on it or anything like I thought. Then they said that they were the only ones that could test it, for $90!!! So what I thought I would try is rotating the tires and if the problem follows it then its the one in the tire. If it is the rear drivers side again then I know its the channel in the receiver.
Old 08-18-2013, 10:01 AM
naturecannon's Avatar
naturecannon naturecannon is offline
Vehicle: 2012 Ram 1500 Quad
Trim Level: Bighorn
Rep:286
naturecannon is a jewel in the roughnaturecannon is a jewel in the roughnaturecannon is a jewel in the rough
I Ran across a few post of yours this morning and they all have had the same insulting tone.
You join the forum just to insult people with comments while hiding behind the screen or are you just a very miserable troll driving a Ford??
Bilsteins 5100, Magnaflow 18, Lines X liner, Airlift 1000, Toyo Open Country A/T II, Cabin Filter, Bully Dog, Billet Catch Can, 3.92, Low Profile ToolBox, Front Cab Window Tint
Old 08-18-2013, 12:11 PM
BlackDropEffect BlackDropEffect is offline
Vehicle: 2012 Ram 1500 Express
Rep:25
BlackDropEffect is on a distinguished road
if you think that is trolling??? thats not even an insult so i dont know about eeven giving the post any attention. but its a frree country and ppl say whatever they want. but yea probly a ford truck driver without any style anyway like u said lol
Old 08-18-2013, 06:02 PM
Gantman's Avatar
Rep:974
It takes only 5 minutes per tire to test a TPMS sensor. Those damn crooks! Hey good luck bud and hope you find the faulty sensor. Your local auto store might diagnose a TPMS sensor for free. Ya never know.
