Old 08-18-2013, 06:30 PM
pstreifel's Avatar
pstreifel pstreifel is offline
Vehicle: 2012 Dodge Ram 1500
Rep:34
pstreifel is on a distinguished road
Originally Posted by Gantman View Post
It takes only 5 minutes per tire to test a TPMS sensor. Those damn crooks! Hey good luck bud and hope you find the faulty sensor. Your local auto store might diagnose a TPMS sensor for free. Ya never know.
My thoughts exactly haha! Thanks, I'll be taking a look at it in the next 2 days.
Does anyone know if I need to replace the sensor with the OEM one or is a aftermarket one acceptable?
Lift 'em high because fat girls can't climb!
Old 08-19-2013, 10:12 PM
kmease kmease is offline
Vehicle: 2012 Dodge Ram Quad Cab
Trim Level: Tradesman
kmease is on a distinguished road
My tires were all at 37 psi and the light came on. Filled them to 40 with not problem.
Old 08-29-2013, 10:51 PM
IBEW3's Avatar
IBEW3 IBEW3 is offline
Vehicle: 2012 Ram 1500
Trim Level: ST Crew Cab 4x4
Rep:25
IBEW3 is on a distinguished road
If your tires are at proper pressure (see above posts), take it to the dealer...Why look to put a band-aid on it by pulling fuses or bypassing it so early in the vehicles life? Just my opinion....
Bakflip G2 tonneau, Factory spray-in bed liner, Flowmaster 50, Bilstein 5100's, Upper Glovebox Add, Tow Hook Add, Husky X-act Floor Liners, ProComp Wheels with BFG KO2's
Old 08-30-2013, 12:10 PM
pstreifel's Avatar
Rep:34
UPDATE: I read on another forum that if you over fill it then bring it down to the correct pressure it goes away... well that's exactly what I did (no I didn't fill them to 100 psi, it was up to 45ish) all of the sudden I was driving off base and it just disappeared. I haven't had a problem since.
Old 08-30-2013, 01:00 PM
Skip.b
Did you check the spare tire?
Old 08-30-2013, 01:33 PM
pstreifel's Avatar
Rep:34
Yes, I did it was good
Old 01-16-2014, 11:10 AM
bucksolid bucksolid is offline
Vehicle: 2012 Dodge Ram 1500 Crew
Color: Black over Silver
bucksolid is on a distinguished road
Default Tire pressure sensor issue resolved!
Thanks to this thread my tire pressure sensor indicator light reset in less than a mile down the road! I set the tire pressure in all 4 tires to the manufacture recommended pressure listed on the sticker in the door (35psi in my case).
To hedge my bet I up'd the pressure in the right rear tire (the one indicated in my console display) to 45psi for awhile to reset it before lowering it to 35psi. I also checked my spare tire per this thread.
The issue went away!
Thanks you guys and Dodge Ram Forum! You save Dodge owners thousands of dollars in unnecessary trips to the dealerships, not that we don't need them, but time is valuable ... and time spent on this forum is well spent.
Old 01-16-2014, 11:18 AM
BTW ... I updated my profile so if I confused anyone with the 2006 2500 Mega Cab Diesel stuff ... I traded to a 2012 1500 Hemi. Liking it real well ... and the savings at the pump!
Old 01-17-2014, 08:20 AM
jimwww's Avatar
jimwww jimwww is offline
Vehicle: 2012 1500 Sport Crew Cab
Trim Level: SPORT
jimwww is on a distinguished road
Send a message via Skype™ to jimwww
It is a faulty sensor that is doing it. Even though pressure is correct - common now to have a bad sensor.
BFG A/T 275/60's - 20 inch wheels, Extang Solid Fold Tonneau. K&N Filter.
Old 01-17-2014, 12:56 PM
paulwbrown230's Avatar
paulwbrown230 paulwbrown230 is offline
Color: Mineral Gray Metallic
paulwbrown230 is on a distinguished road
My 2012 Big Horn says 35 on the door.
