Old 01-20-2014, 05:09 PM
ghorn ghorn is offline
Vehicle: 2012 Ram 4X4 Crew CAb
Trim Level: LoneStar Rambox
Rep:74
ghorn will become famous soon enough
The tire pressure is dependent upon the exact tire size (different with different wheels also, btw) and the empty-wt versus load-rating of your exact model truck with it's factory options. Two otherwise identical appearing trucks may have different recommended tire pressures for those sort of things.
Old 02-15-2015, 04:57 AM
MEGA RAMBOX1 MEGA RAMBOX1 is offline
Vehicle: 2012 RAM 2500 Mega Cab Ram Box
Engine: 2011-2012 409ci (6.7L) Cummins Turbo Diesel 350hp 800lb/ft
MEGA RAMBOX1 is on a distinguished road
Our 2012 2500 has a light load button on the dash and when it in it lights up and the tpms is in light load but if the light is not lit the tps is in he heavy mode an if the tire pressure is not correct he low pressure light comes on in he instrument cluster. Dealer tells me they have constant problems with the tpms system.
Old 02-17-2015, 03:40 PM
shadango shadango is offline
Vehicle: 2012 Dodge Ram 1500 Big Horn
Rep:25
shadango is on a distinguished road
Originally Posted by Gantman View Post
Man, a 2012 out of warranty already?
Why is that a surprise? Mine is up in a month. There are many 2012s out there that will be out of warranty now or soon.
Old 02-22-2015, 08:39 PM
Gibby Gibby is offline
Vehicle: 2012 Ram
Color: True Blue Pearl
Rep:22
Gibby is on a distinguished road
So is the tire pressure indeed suppose to be 40psi? The sticker on my door says 35 and that is what I always inflated to... seems like my light doesn't come on till it drops below 30psi
Old 02-22-2015, 09:23 PM
dabranco dabranco is offline
Vehicle: 1996 dodge ram
Color: red
dabranco is on a distinguished road
It is a 5lb leeway +/- But most are set off with as little as 2.5lbs. Inflate them to regular manufacture recommendations and all should be good. The BCM (Body Control Module) stores the information and it can be adjusted just takes someone knowledgable and some time (about 2 hours) to do all 4 tires (5 if the spare has a sensor) it is not all that hard but most dealerships won't do it.
