OEM running board feel loose - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2012 Dodge Ram Forum
Old 08-15-2013, 10:25 PM
Kelevra's Avatar
Kelevra Kelevra is offline
Vehicle: 2012 Dodge Ram
Rep:91
Kelevra will become famous soon enough
Default OEM running board feel loose
Last thread. I swear!!!
so I installed the Mopar/OEM tubular running boards and they are tightly secured but when you step on them they give a bit. I almost feel like they're gonna pull out or snap off using them. I collapsed the rivnuts as per the instructions ~3.5 turns of the nut until they REALLY fought back and I could barely turn them anymore. is this just the nature of the board or did I not do something right?
Old 08-15-2013, 11:58 PM
Vehicle: 2016 dodge bighorn 1500 hemi
Color: MAXIMUM STEEL
Rep:783
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
i would go to a dealer and see if any trucks on the lot have them and try em.
Old 08-15-2013, 11:59 PM
Kelevra's Avatar
Rep:91
I did and they were all solid
Old 08-16-2013, 01:22 PM
Kelevra's Avatar
Rep:91
ok, maybe the term feeling loose is bad, they're tight, but they flex when stepped on. Is that normal? i need answers
Old 08-16-2013, 08:21 PM
06 BigHorn's Avatar
06 BigHorn 06 BigHorn is offline
Trim Level: Express Quad Cab
Color: Deep Cherry Red
Rep:153
06 BigHorn has a spectacular aura about06 BigHorn has a spectacular aura about
If the rivet nuts were not completely secure when installed they will stretch, becoming loose. If you stretch them too much you'll bend the mounting locations. Your dealer has a special plate if that happens.
I had problems with mine becoming loose, bent the mounting holes. but the dealer bent them back in place & added new rivet nuts
It's a truck, not a cream puff
Old 08-17-2013, 11:03 PM
Studbuster's Avatar
Studbuster Studbuster is offline
Vehicle: '09 RAM 1500 4dr
Color: Light Graystone Pearl
Rep:61
Studbuster will become famous soon enough
I have factory running boards, 50K on truck, they are solid. (190#)
It's my truck and I want it the way I want it!
IF YOU DON'T HAVE TIME TO DO IT RIGHT, WHEN WILL YOU FIND TIME TO DO IT OVER??
Dave
Old 08-18-2013, 11:12 AM
highwayman1's Avatar
highwayman1 highwayman1 is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Tradesman
highwayman1 is on a distinguished road
Well , mine ripped completely out! Pretty cheap metal for mounting those things. I think they should have used the body mounts or something. Oh, maybe they would bend too! Sorry , just had to vent a little bit.
