Old 08-16-2013, 12:26 AM
dodgehemi0 dodgehemi0 is offline
Vehicle: 2013 Sport Crew
Rep:26
dodgehemi0 is on a distinguished road
Default 8 speed trans tow ratings?
Why are the tow ratings the same as the 6 speed trans? My 3.55 gears can only tow 8500lbs. My Titan with 3.31 and a 5 speed could tow 9800lbs. What's the deal guys anyone have an idea?
Old 08-16-2013, 05:37 AM
maw76's Avatar
maw76 maw76 is offline
Vehicle: 2013 RAM 1500 QC
Trim Level: Outdoorsman
Rep:49
maw76 is on a distinguished road
Most likely so they don't have to worry about replacing the transmission. No doubt that the power train can take it might also be for acceleration from a safety point of view.
Old 08-16-2013, 08:17 AM
Parkersdad Parkersdad is offline
Vehicle: 2013 Dodge Ram 2500
Color: Mineral
Rep:21
Parkersdad is on a distinguished road
If they ever start using this mandatory testing system all of the trucks tow ratings will go down.
Old 08-16-2013, 08:28 AM
Rep:26
So why did the tow rating of the v6 8 speed combo go up for the 845rfe trans apposed to the ZF trans and v6 combo tow rating?
Old 08-16-2013, 08:43 AM
spp spp is offline
Vehicle: 2008 Jeep Wrangler
Trim Level: Sahara
Color: Steel Blue
Rep:106
spp will become famous soon enoughspp will become famous soon enough
Parking prawl was strengthened in the 8 speed for 2014 (Source). That accounts for the 8 speed/V6 getting a better tow rating in 2014.
Old 08-18-2013, 10:02 PM
Ramzaq Ramzaq is offline
Vehicle: 2009 Ram CC 4X4
Trim Level: SLT, Big Horn
Color: Black Pearl coat
Rep:233
Ramzaq has a spectacular aura aboutRamzaq has a spectacular aura aboutRamzaq has a spectacular aura about
The final gear ratio in the 5, 6, and 8 speed trans are all the same, no difference. So that is why they have the same tow ratings. The rear end ratio determines how much it will tow in this situation. This is the recommended limit Chrysler has decided on, most likely to keep problems with warranty costs and liability down.
The 8 speed has a maximum tq rating of around 520 ft lbs torque and the 5 and 6 speed have a maximum of around 420 lbs. Can't remember the exact maximums but they should be close as far as I remember.
Old 08-19-2013, 01:21 PM
Thunderhorse's Avatar
The Sound of Eight Hooves
Rep:545
Thunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of light
The benefit you get from the 8 speed over the old 6 speed comes from it being a lighter transmission.
Thunderhorse-Built: 25 Feb 2013 Warren, Michigan; Bought: 28 May 2013
Huskyliner Weatherbeaters, door edge guards, Line-X bedliner, Kryptek Typhon Cordura seat covers w/ MOLLE panels (review), Console Vault (install/review), Bilstein 4600s (thread), BFG T/A KO2 LT275/60/20s (thread), Borla XR-1 (thread), Matte black Plasti-dipped center console bezel, BT catch can.
Old 08-19-2013, 05:18 PM
phobos512's Avatar
phobos512 phobos512 is offline
Vehicle: 2013 Ram 2500 4x4 CCSB CTD
Color: Maximum Steel
Rep:6
phobos512 is an unknown quantity at this point
Um, the main benefit you get from an 8-speed is that the gear ratios are more closely spaced which allows the engine to stay in its powerband. It being lighter is not the primary reason. All things being equal (i.e. manufacturing techniques and materials) a transmission with more gears ought to be heavier. Obviously not the case here but the 8-speed being lighter is not the main reason you'd want it...
Matt || 2013 2500 Laramie || CCSB 4x4 CTD || Maximum Steel || Nitto Terra Grapplers 305/70-17s
Old 08-19-2013, 05:20 PM
phobos512's Avatar
Rep:6
Erm...it's not mandatory - that's why only Toyota uses it thus far. It's a suggested methodology for standardizing tow ratings across multiple manufacturers. Which is why it'll more than likely never be "mandatory" unless the government forces it to be so via fraud accusations, accident investigations for vehicles that show they were misrated, or some such.
Old 08-19-2013, 05:34 PM
Rep:545
Maybe I should be more clear: the reason the tow ratings improved slightly between 2012 and 2013 is because the 8 speed is lighter than the old 6 speed. All things are not equal and how much the 6 speed should weigh are irrelevant because they are not similar in manufacturing techniques or materials. the 8 speed is lighter, the 6 speed is heavier, that's all that matters. The fact that you have more favorable ratios with the 8 speed had no impact on tow ratings for the 8 speed in 2013.
The final drive ratios are 0.67 for both transmissions in their highest respective gears. The transmission is not the limiting factor behind the tow ratings, the differential is. Yes you have a much lower first gear with the 8 speed (actually the first 2 gears), but the differential is under the same amount of stress it would be if the truck had the 6 speed because the speed of the output shaft and therefore input pinion will be the same at the same speeds. The only difference is that the transmission will be in a different gear.
I love my 8 speed, the added gears have improved power availability substantially but do not allow it to tow more than it could if it had the 6 speed, the weight savings does. There are other threads on this topic as well.
