Old 08-16-2013, 11:51 AM
RufNutt RufNutt is offline
Vehicle: 2012 Dodge Ram
Color: RED
RufNutt is on a distinguished road
Default Biggest 17 " Tire Size
Hello I am setting my truck up for better hauling conditions and driveability. I am going to install a tlc air suspension for hauling this weekend. I have ordered bilstein's for the front. Will install them next to compensate for any lift I end up getting from the air bags after I find the psi setting I want for the airbags.
My biggest question is next week I want to upgrade to a bigger tire but keep my stock rims. Tires for hauling . When trailer season is over I will most likely upgrade wheels and rims for off season. The off road tires do not wear as good for long hauling so really I will need to rotate to a more aggressive rim and tire when I am done. .I am presently running 265/70/17 but I can't seem to find a sticky or a post on actual biggest tire I can run without spacers on a 17 inch stock rim. I want to upgrade my trailer hauling tires at this time to biggest size possible.
So I am asking what do you guys run for tire size without any modifications?
Cheers
Old 08-16-2013, 12:11 PM
toober's Avatar
toober toober is offline
Trim Level: Tradesman
Rep:26
toober is on a distinguished road
I'm with you on that one. When the times comes to replace my tires, I'll debate between the beefiest I can put on without a lift and staying under the fenders or go with lift and 35s. Can anyone confirm 31s or 33s?
Old 08-21-2013, 05:05 AM
hotwing457's Avatar
hotwing457 hotwing457 is offline
Vehicle: 2011 Ram 1500
hotwing457 is on a distinguished road
i'd guess you could safely get 285/70/17 on the stock rims just fine, anyone else chime in on that?
Duratrac 315.70.17 on 17x9"-12mm / Bilsten5100 2.75" / CoilRiteAirbags / TCC CoilSprings /
Old 08-21-2013, 10:25 AM
Jpeetro's Avatar
Jpeetro Jpeetro is offline
Vehicle: 2015 ram 2500
Trim Level: tradesman 8 ft
Engine: 2015-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 865lb/ft (Aisin ASC69RC Automatic)
Jpeetro is on a distinguished road
I'm running 285/70/17 on mine just fine for 20,000 miles now.
Old 08-21-2013, 11:17 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
285 wide is as big as you can go on stock wheels. with no level/spacers. (rim size really has nothing to do with it, it's the same for 17, 18, 20, etc)
you posted this in the leveling section...so do you plan on leveling or no?
