Old 08-16-2013, 01:08 PM
philjeeper philjeeper is offline
Vehicle: 1996 Dodge Ram
philjeeper is on a distinguished road
Default Right Rear Brake/Turn not working
My right rear brake/turn signal isn't working. The running light works and the problem isn't the bulb. The front turn signal works also.
Anyone have any ideas on what it could be?
I'm going to check the fuses now.
Old 08-17-2013, 03:10 PM
hollonator's Avatar
hollonator hollonator is offline
Vehicle: 2007 Dodge Ram 1500
Trim Level: SLT Quad Cab 4x4
Color: Flame Red Clearcoat - R4
hollonator is on a distinguished road
Actually the only thing I could think of would be the bulb.
Here is my reasoning: If the front right turn signal works correctly than it cannot be the relay, as the turn signal relay acts on the entire side of the vehicle. It also couldn't be the brake switch or the left brake light and 3rd brake light would not work. The bulb has 2 "filaments" (wires) inside of it. Have you actually replaced the bulb to make sure its not the problem? It would be the cheapest fix. Maybe a wire running to the right rear of your truck has come loose, corroded, or disconnected. 1 wire operates both the brake and turn signal "filament", another wire operates the tail light/parking light feature. Trace your wires starting at the bulb.
2007 Dodge Ram 1500 SLT Hemi 4x4
Custom Flowmaster 50 Series HD Exhaust
