Old 08-12-2013, 10:10 AM
USAF Long's Avatar
USAF Long USAF Long is offline
Vehicle: 2013 Ram 1500 RCSB
Rep:69
USAF Long will become famous soon enough
Send a message via AIM to USAF Long
Default Ran my truck at Tri-State Dragway
I made about 10 runs. The track was not busy but it wasn't prepped good at all. There was no VHT. Just water and rubber that was it.
My first run was my best. I think it was 14.96@90mph. I turned off traction control, used tow/haul mode, and left it in drive. Skipped the water box, and just punched it and ran.
That was my only 14 second run of the day. I tried the tow/haul off, burning out a bit, stalling up the converter, tried the other lane, lowered my tires to 25 psi out back, manually shifted 1-2-3...
Best MPH was keeping it in 3rd (2nd prime) and I got a 93.98 mph. All the rest of my times were between 15.0-15.45 and anywhere from 90-94 mph.
I want to get on another track thats closer that has new surface and they spray VHT on the starting line. My 60' times were all 2.2-2.4 and I was spinning every time which I can't even do on the street. The damn rubber on the track was hurting my traction.
I had the spare and jack and tailgate removed. Air filter removed, 1/4 tank of 93 octane.
Only modification I have done is replaced the factory muffler with a Magnaflow Y-pipe.
Here's a video my girlfriend shot with my digital camera... the digital zoom sucks.
-Scott Long-
2013 Ram Express RCSB: 5% tint, de-badged doors, muffler delete y-pipe, K&N panel filter.
Best Run: 14.60@96mph with 2.4 60' at Kil-Kare Raceway in Ohio
Old 08-12-2013, 11:33 AM
Copperhead2013's Avatar
Copperhead2013 Copperhead2013 is offline
Vehicle: 2013 Ram Crew 4x4
Color: Copperhead Pearl
Rep:50
Copperhead2013 will become famous soon enough
Kil-Kare Dragway in Xenia has Test--n-Tune on Thursday Nights.....
Mod List- Lo-Pro Tonneau, Billet Engine Bay, r/t Grille.Black Billet locking fuel door, K&N drop in filter, Borla Cat Back Exhaust.
Old 08-12-2013, 12:50 PM
hemiexp04 hemiexp04 is offline
Vehicle: 2014 blacktop qq 4wd 8speed
hemiexp04 is on a distinguished road
what was the weather like? these trucks hate the heat they heat soak bad . Did you let the truck cool down any in between runs? Wait till weather cools down some and go back. Let the truck sit and cool for abt 45 min and make a pass. Should be 14.5-14.2 all day long.
Old 08-12-2013, 12:53 PM
USAF Long's Avatar
Rep:69
it was 83 and humid sticky. I let it sit an hour but my first run was the best right when we got there after driving down about an hour, stopped across the road for gas, went to tech, then parked it for 20 minutes and made my first pass.
I went to Kilkare Thursday but it was closed since it rained earlier. I'm going to be out there this Thursday god willing its not raining. Kilkare preps the track better. Its so sticky I lost a shoe pushing a car off one time.
-Scott Long-
Old 08-12-2013, 03:25 PM
Redhemi03 Redhemi03 is offline
Vehicle: 2003 hemi ram
Trim Level: Slt
Color: Flame red
Rep:26
Redhemi03 is on a distinguished road
What state are you in?! Look up what your DA was on dragtimes.com , go to tools and select DA calculator and put in your track, date and year, and select about what time it was that you ran and it will let you put in your 1/4 mile time and it will correct it at a 0 da, let us know what it says
2003 QC HEMI. 8.46@ 79.50, fastest NA 03 QC
Sidewinder cam, power wire,Tmr delete, edge 2800, hedman long tubes , Hedman ory pipe, 3" cutout, magnaflow 24", k&n CAI,Sharadon stage 3 VB, 4.56's, superchips 91
Old 08-12-2013, 04:02 PM
USAF Long's Avatar
Rep:69
Corrected it says: 14.572 @ 93.355 MPH
-Scott Long-
Old 08-13-2013, 06:40 AM
Dragpac's Avatar
Dragpac Dragpac is offline
Vehicle: 2013 dodge ram
Rep:33
Dragpac is on a distinguished road
Cooler air is coming and you will get faster.good luck.
[SIGPIC]
]2014 sport crew cab hemi 8 speed 3.92 gears
Old 08-13-2013, 08:14 AM
USAF Long's Avatar
Rep:69
I'm sure the humidity wasn't helping. It had been raining all week and the air was nice and sticky. It had been in the 70's and low humidity the past week which would have been better. I'm more disappointed about the lack of prep on this backwoods track than the weather. No matter what I did I couldn't get the big truck moving off the line worth a damn. I found some 17x9" rims I'm going to save up for and then put some 275/50 M&H drag radials on them and some Nitto's up front. That should cut weight, increase traction, and lower my effective gear ratio up around 4.30:1 for faster acceleration.
I also want to put a tuner on it but I'm holding out for Diablosport to release a 2013 tuner as I have a friend who can write me a tune. I've heard the bully dog isn't really that great and people have had a hell of a time getting the right tune files on it.
I want to do an intake and a throttle body upgrade, I'm thinking Vararam might be the best one out there. I looked at nitrous systems and found one that has an 85mm throttle spacer plate with the nozzles in the plate so I could match that with an 85mm ported throttle body, then hide the soleniods somewhere low on the firewall and put a rubber hose over the nitrous lines to make them look like vacuum hoses.
I really want to do 4.10 gears and a 3200 rpm converter but those mods are expensive due to the installation costs added and I would have to pay someone to do it. I could do the converter myself but I don't have a big garage at my apartment and have no idea how to set up and shim gears so I'd be stuck paying labor. I will probably buy the parts this winter though and put them on the shelf and get them installed before next summer.
-Scott Long-
Old 08-13-2013, 08:18 AM
USAF Long's Avatar
Rep:69
Eventually a cam and headers. I'd love to get this truck in the 12's on motor and either low 12's or high 11's on nitrous.
-Scott Long-
Old 08-16-2013, 09:40 AM
USAF Long's Avatar
Rep:69
Ran it at Kil-Kare last night. Despite the better prepped track with fresh surface, I was still pulling 2.3 second 60' times.
I only made two runs because the place was a zoo and people kept blowing up their chit and scattering parts and fluid on the track which took a long time to clean it up.
First run I got lined up with an F-250 Super Duty quad cab long bed power stroke w/ about a 6" lift and 35's. He had a-pillar pod and a 5" exhaust and not sure what else but it was loud and smoked like a chimney.
I was hoping this would be a good race because I have friend with a similar truck who is talking s%&* but I can never catch him out when I'm in the Hemi. We lined up and got the better reaction time .499 to his .559 and I pulled a better 60' at 2.31 to his 2.61. I jumped ahead and held the lead but he was keeping pace for a while. At the 330' I ran 6.33 to his 6.62 and I had him at the 1/8th with 9.65@74.76mph to his 10.27@59.96. Shortly after the 1/8th I heard a loud backfire and he fell off behind blowing smoke. At the 1000' mark I had him good at 12.45@87.16mph to his 14.33@55.30 and at the end I took him by a longshot. I ran 14.88@91.30mph and he rolled through at 18.48@50.75mph.
I'd guess he popped an intercooler pipe loose. He was running later but I couldn't see his times from where I was in the staging lanes. I like to race my truck but I also like seeing what other cars run and when you're stuck in line all night and can't see the boards its not as much fun for me.
The 2nd run I got lined up next to an LT1 Firebird Formula with a huge ram air lift off hood (WS6 style scoops but much taller). It had drag radials on the back on a set of LS1 Z28 wheels. I knew I was going to lose but I was hoping to run quicker than my last run. I got taken to school. R/T .216 to their .085. 60' was 2.33 to their 1.98 (not as good as I thought that car would hook). I crossed the 330' in 6.39 to their 5.63 and ran the 1/8th in 9.73@74.31mph to their 8.62@82.37mph. My truck ran 1000' in 12.55@87.19mph and the Firebird ran 11.21@93.93mph and I was staring at it's tail lights when I crossed the line at the 1/4 in 14.92@95.08mph. The Firebird ran 13.41@102.41mph.
I set a new best E/T with my 14.88 run and my new best MPH at 95.08 (left the trans in "3"). The first run I just left it in "D" and had tow/haul mode on and traction control was off for both runs.
Had a guy come up to me in the pits and ask about my truck. He had a Hemi quad cab 4x4 that ran 15.7 and he was interested in my exhaust setup so I showed it to him and let him listen to it.
I still can't get this truck off the line. I went around the water box and then punched it quickly but it didn't spin this time. If I'm spinning at this track I'm not hearing it and they had been spraying VHT all over the starting area.
-Scott Long-
