Old 08-16-2013, 11:35 PM
Gilbo892 Gilbo892 is offline
Vehicle: 2012 2500 longhorn
Trim Level: Longhorn limited
Color: White/tan
Gilbo892 is on a distinguished road
Default Stock 2012 4wd 2500 level
Anyone have knowledge of leveling stock suspension without buying a kit, I had adjustable torsion bars on Z71. Not at all familiar with this beast!!!
Old 08-17-2013, 12:00 AM
richmond richmond is offline
Vehicle: 1999 Dodge Ram
Rep:177
richmond has a spectacular aura aboutrichmond has a spectacular aura about
Default Not that I'm aware of
But hey, a 2" front leveling kit is awful cheap, requires an alignment afterwords though. Assumes no warranty issues. (I haven't seen a warranty in years) R...
Old 08-17-2013, 12:33 AM
skinnysfd's Avatar
skinnysfd skinnysfd is offline
Vehicle: 2012 dodge ram 2500
Trim Level: big horn
Rep:53
skinnysfd will become famous soon enough
on my 2012 2500 i put leveling springs on it. i bought em from sdtrucksprings.com i believe it was 200$ easy way to do it . they replace your factory springs and wont void your warrenty at least thats what ram told me.
2012 RAM 2500 HEMI AFE CAI flowmaster dual exhaust,airlift 5000 bags w/onboard compressor,shaved tailgate,2.5" lift/level tuftruck front springs,bushwacker pocket flares,gear alloy wheels, goodyear duratracs 315/70/17,bd gt hemiplus tuner much more coming
04.5,2006 5.9l cummins
Old 08-17-2013, 12:52 AM
APSTRAM's Avatar
APSTRAM APSTRAM is offline
Vehicle: 2016 Ram 2500 Crew Cab 4x4
Rep:89
APSTRAM will become famous soon enough
I did the same with the tuff truck springs from SD truck springs and a BD diesel adjustable track bar.
Old 08-25-2013, 12:21 PM
Imakebrakes Imakebrakes is offline
Vehicle: 2011 ram 1500
Imakebrakes is on a distinguished road
Had tuff spring on my old truck. I like them
Old 10-01-2013, 11:51 PM
Blownsquidink Blownsquidink is offline
Vehicle: 2011 2500 Ram 4x4
Blownsquidink is on a distinguished road
A 3 inch lift levels out the truck perf. I got mine from ebay for $70 after shipping, and you can still use the stock shocks. After a $100 alignment you in. I've seen just the spacers go for more than that. Good luck
Old 10-02-2013, 12:08 AM
brandonjansen's Avatar
Trim Level: Laramie Limited
Rep:2067
IMO leveling it by doing springs, shocks, and an adjustable track bar is the best option to level and HD truck.
Check out Top Gun Customz 2.5" progressive rate coils, Bilstein 5100 shocks and the BD Diesel adjustable track bar. That's what I'm thinking of putting on my 2012 3500.
Old 10-02-2013, 11:22 AM
APSTRAM's Avatar
Rep:89
Replacing the springs and shock are the way to go. No matter what lift method is used the adjustable track bar is a must if not the truck goes down the road dog legged.
Old 10-04-2013, 05:06 PM
Astartes Astartes is offline
Vehicle: 2010 4.7l v8 4x4
Rep:160
Astartes has a spectacular aura aboutAstartes has a spectacular aura about
On my 1500 i used Bilstein 5100's, They're adjustable... Not sure if they work for 2500s?
Greater love has no one than this, that a man lay down his life for his brothers. -John 15:13
My Mods
Old 10-04-2013, 05:17 PM
Rep:2067
Nope, completely different suspension set up. To start the 2500/3500's are solid axle, not IFS like the 1500's. And they use a separate spring and shock rather than a strut assembly.
