Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
Old 08-17-2013, 09:11 AM
sharker sharker is offline
Vehicle: 2013 ram sport
Trim Level: sport
sharker is on a distinguished road
Default Loose oil filter
About 2 months after my first oil change i found a little oil on my garage floor. Went under the truck to find that my oil filter was loose. Mad as all heck i hand tightened then a little pull with the oil wrench. I thought i had it but now 3000 miles later, it's leaking again. Is the oem filter not that good? Anybody else have this problem and is there a fix or alternate filter.
THANKS IN ADVANCE
Old 08-17-2013, 10:11 AM
Hermes1 Hermes1 is offline
Vehicle: 2015 Big Horn 3500 Cummins TD
Rep:2559
Could be the gasket was not properly seated, possibly the previous gasket came off and the new filter was placed over it or just a bad gasket. I would do an oil and filter change or just the filter if you do not mind the mess.
Old 08-17-2013, 10:38 AM
Grubrunner's Avatar
Rep:3883
If it's a repeat issue, as you described, I would point the finger at the filter and replace it ASAP before it fails completely.
Grub out!
Old 08-17-2013, 10:58 AM
Rep:2657
check for a double rubber gasket, some Techs just make the oil filter change without looking to see if the old one stuck onto the engine block
__________________________________________________ ___________
this is mostly just my thinking
if you decide to check it out for yourself, use a quart Baggie over the oil filter to catch most of the oil that will overflow from inside of the filter
I would also use a plastic grocery bag to lay over the metal bars under the filter, just to keep things cleaner
of coarse have a new filter handy, personally I use anything BUT a FRAM, my preference is a WIX, NAPA Gold, or CARQUEST.
when removing the oil filter, check for where it screws on to see if there is a rubber gasket still on the engine, it should be just metal
when you put the new filter on, put some oil into the new filter before screwing it on, it doesn't have to be full, I just like to have some in there, so the engine is not run dry for even a little bit, also put a light coat of oil onto the rubber gasket, I use my finger to do that
Good Luck
Old 08-17-2013, 11:31 AM
TinMan68 TinMan68 is offline
Vehicle: 2013 Dodge Ram 1500 Express
Trim Level: Express Quad Cab
Rep:45
TinMan68 is on a distinguished road
Everybody badmouths Fram cause of the way a certain review was handled. You might want to read this also.
http://www.jeepforum.com/forum/f9/ea...-ohio-1261517/
2013 Dodge Ram 1500 Express Quad Cab 5.7L Hemi With 6 Speed Automatic And 3:55 LSD Gears and 20 Inch Rubber
2002 A6 3.0L 30V Quattro Avant Auto
2003 Nissan 350Z Enthusiast Model 6 Speed Manual
Old 08-17-2013, 06:28 PM
ValleyRacer ValleyRacer is offline
Vehicle: 2013 Ram RT
Trim Level: RT
Color: Steel Blue Metallic
Rep:136
ValleyRacer will become famous soon enoughValleyRacer will become famous soon enough
Default How to tighten an oil filter
Over tightening an oil filter is just as improper as inadequately tight.
Using hand strength (assuming you aren't a power lifter ) - just SNUG the filter to the baseplate. Firmly SNUG is all. Over tightened filters can make the oil filter rubber gasket "squirm" out of position from the top of the filter.
THEN, the filter is loose all of a sudden and you have a drip or leak or catastrophe.
The first part of an oil change is to remove the FILTER and verify the rubber gasket is still on the used filter. Then proceed making sure the NEW filter has a gasket intact.
Certainly it's true FRAM has upped the ante with some quality improvements, but those ORANGE Fram filters are worthless.
Old 08-17-2013, 06:46 PM
hemidon hemidon is offline
Vehicle: 2013 Dodge Ram 1500 CC 4x4
Color: True Blue Pearl
hemidon is on a distinguished road
Mine leaked after the first dealer oil change. Was a bad rubber gasket on the filter.
Old 08-17-2013, 07:40 PM
Trim Level: RT
Rep:136
Default This is why I teach GASKET thinking
Having shown many many people how (and why) to change their own oil - the first thing is GASKET OFF, new gasket ON.
When removing the used filter, FIRST check that the gasket came off.
Then lightly lube the new oil filter gasket making sure the gasket is seated radially in it's groove.
Then with hand pressure firm SNUG tighten only. An improperly over-tightened filter can make the rubber gasket "squirm" out of position.
Then, you have a leak, drips, loose filter and a potential catastrophe.
Old 08-17-2013, 08:21 PM
Trim Level: sport
Color: green
Rep:657
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
after doing my first change on the truck, not to mention how tight the orig. filter was on, i found you have to make these filters a little more snug than we are used to, or it will leak.
