Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Towing
Towing 3rd Gen Dodge Ram Towing Questions
Old 08-19-2013, 11:39 AM
Stump3r's Avatar
Stump3r Stump3r is offline
Rep:1266
Total load control is one of our platinum vendors, read through this forum....http://www.ramforumz.com/forumdisplay.php?f=231
This will give you an idea as to how airbags work etc.
Big Red my old 2011 Sport
Old 08-19-2013, 11:41 AM
hollonator's Avatar
hollonator hollonator is offline
Vehicle: 2007 Dodge Ram 1500
Trim Level: SLT Quad Cab 4x4
Color: Flame Red Clearcoat - R4
hollonator is on a distinguished road
Originally Posted by shreddy View Post
I am looking at these
http://www.sdtrucksprings.com/index....125&x=101&y=13
They claim 50% "capacity" increase.
Available in regular and variable rate.
I looked into those too, but they aren't made for my truck...only the 2009-2013. My question in regards to that is, will rear shocks from a 4th gen bolt onto a 3rd gen? It would be as simple as mounting on the cross member under the bed and on the axle...I have known of a lot of different vehicles being able to swap out shocks, are the 3rd gen and 4th gen Rams capable of doing this?
2007 Dodge Ram 1500 SLT Hemi 4x4
Custom Flowmaster 50 Series HD Exhaust
Old 08-20-2013, 03:44 PM
Detroit3000's Avatar
Detroit3000 Detroit3000 is offline
Vehicle: 2009
Trim Level: Big horn
Color: Brilliant Black Crystal Pearlcoat
Rep:68
Detroit3000 will become famous soon enough
I have a 2008. I installed the bilstiens to level it. Once it was leveled when I would hook my camper up it would "sag" a little since I removed the factory rake. I went with the firestone ride rite air bags. They installed easily with a few wrenches in about an hour and a half in my driveway. I decided not to go with a onboard compressor, I did tee the airlines to both bags together and just use one Schrader valve mounted in the bumper to fill/empty.
Old 08-20-2013, 04:12 PM
hollonator's Avatar
That is a really nice setup. One question though, if I remember right they increase carrying capacity by up to 5,000lb (advertised)...how do you know you are not putting too much air in them and risk blowing the bags?
Old 08-20-2013, 04:20 PM
Vehicle: 2009
Rep:68
If I remember correctly the bags are rated to hold up to 80psi and the lines are rated for 100psi. I check them with a tire gauge. When I first installed them I left about 15 psi in them, first time I hitched up the camper I filled them to 38 psi to bring me level and honesty I just left them like that. Since its just a normal Schrader Valve filling and checking is no different than doing the same as you would your tires
Old 08-20-2013, 07:25 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
^I don't have that same kit but I have the airlift bags and T'd my lines and ran the valve the same way. The bags on my truck have a max psi of 35psi and have such little volume that about 10-20 pumps on a bicycle pump fills it to that pressure. So I just leave a pump in my truck toolbox. I don't like the extra electronics, headache, etc of an electric pump when it's so easy to do by hand. Literally takes about 1 minute to fill up.
Sean
Old 08-21-2013, 07:33 AM
hollonator's Avatar
I have to admit I like the idea of air bags
Old 08-23-2013, 06:56 AM
Lake O Hunter Lake O Hunter is offline
Vehicle: 2004 Dodge Ram 1500 QC 4x4
Color: Gray
Lake O Hunter is on a distinguished road
air bags are great, but more work to install. Coilover's are simple and effective. I have air bags on the rear of my 4th gen ram, but they are super easy to put in with the coil spring suspension. If I had leaf springs I wouldn't install air bags as it's more work, I'd get coil overs. I had coil overs(monroe) on my s10 as well and they were great. I had put 2000 lb in that truck a few times and it handled it.
You can also look in to air shocks. They are easy to install. I had them on my F100 and were great.
What brand of coilovers did you install on the ram?
Old 08-23-2013, 09:53 AM
snrusnak's Avatar
Rep:1385
I don't have coilovers on my ram. My dad has the monroe coilovers on his 05 ram. He loves them. They will lift the back of the truck a bit, and have a lot of capacity.
Sean
Old 08-25-2013, 12:01 PM
Color: Gray
Thanks and sorry I misread I thought you installed them on your truck...
