Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Body & Interior
Old 01-25-2014, 06:50 PM
Downunder dodge Downunder dodge is offline
Vehicle: 2010 2500 dodge ram
Trim Level: Larimine
Downunder dodge is on a distinguished road
Default Straightening a seat?
I just noticed that the back of the seat is not straight. When you push back on the seat and and push the button to make it lean forward it moves unevenly the right side moves infront of the left side.
It's like it's jumped a cog. Is there any way of getting it straight again?
Old 01-26-2014, 10:51 AM
LowUFO's Avatar
LowUFO LowUFO is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Sport Crew
Color: True Blue Pearl
Rep:1123
You should take the seat apart to do it right. You might be able to sit in the back seat and put your feet against the back of the front seat and twist it back. But that won't be a permanent fix if you're not a lightweight. The right way is to take the seat apart and see if a spot weld or too have broken. Or if it is indeed a problem with the hinge bracket. Maybe a cross brace has broken. Bottom line, you have to open it up to find out.
R.I.P. MOPAR BIG HORN (KYLE)
Old 01-26-2014, 06:02 PM
Thanks for that, how hard is it to open it up? I might cry cutting in to it with a knife!
Sounds like a job for a professional, other wise i might be sitting on a milk create by the time I've finished with it
