magnaflow questions - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8
Old 08-18-2013, 06:27 AM
whitev8's Avatar
whitev8 whitev8 is offline
Vehicle: 2012 Dodge 4.7
Trim Level: Tradesman
Rep:17
whitev8 is on a distinguished road
Default magnaflow questions
what is the difference meaning purpose between the magnaflow cat-back system for $800 or just the muffler for 100 bucks. Which muffler is the most popular for the 4.7. I hoping to get at least 1 to 2 mpg gain if possible. thx
Old 08-18-2013, 02:54 PM
MaximumSteelExpress's Avatar
MaximumSteelExpress MaximumSteelExpress is offline
Color: Maximum Steel
Rep:37
MaximumSteelExpress is on a distinguished road
Muffler is for sound more or less and with the whole cat back system u should see some better overall performance gains. Stock pipes are pretty restricting so the full system will offer better flow.
14" Maggie, 87mm TB, Green Perf. AF, Diablosport T1000(Hemifever),Smoked Heads/Tails/3rd Brake
Old 08-18-2013, 10:27 PM
RogerRamJet's Avatar
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
Cat back is where they cut out your current exhaust system and install new pipes and muffler from the cat back. A muffler, for $100 bucks, is cut out and a new muffler is installed. On my 4.7 I got the Maggy 14". You oughta listen to some of the sound clips, then you can decide for yerself which sound you like better.
Old 08-19-2013, 03:22 PM
whitev8's Avatar
Rep:17
thx , I will go with the bolt on mufflex dods18 from the sound clips on you tube. i was going to order a magnaflow cat back but Iam glad i ask because i cant weld or cut pipe but i got a socket set.
Old 08-19-2013, 05:00 PM
Rep:2968
Welding is the way to go, but if all you have is a socket set, then that'll have to do. Good luck and have fun. Throw up a pic and a sound clip of it when you're done.
Old 08-19-2013, 05:28 PM
Grubrunner's Avatar
Rep:3883
What Magnaflow catback model number are you looking at?
Grub out!
Old 08-19-2013, 06:05 PM
whitev8's Avatar
Rep:17
It was the magnaflow 16386
I guess it not to true cat back because it bolts on just before muffler per the instructions. It looks like rip off because the charge you a lot for ss pipe you all ready have.
Old 08-19-2013, 06:11 PM
Grubrunner's Avatar
Rep:3883
Looks like a "true" catback to me.
It's only a rip-off if the existing OEM system is identical in every way to the AM catback you're considering [SS grade, pipe diameter, tip diameter, muffler type, etc]
Good luck.
Grub out!
Old 08-19-2013, 09:01 PM
pstreifel's Avatar
pstreifel pstreifel is offline
Vehicle: 2012 Dodge Ram 1500
Rep:34
pstreifel is on a distinguished road
There is a way to take the muffler off with a socket set???? I when under there and saw the clamp loosened it and took a few hard whacks at it and nothing even budged. Maybe I had my purse that day but I thought I gave it what I could.
Lift 'em high because fat girls can't climb!
Old 08-19-2013, 10:17 PM
Rep:2968
Yes, the stock mufflers are held together with brackets, but you gotta remember, 1) they are meant to be super tight and therefore the tolerances are extremely tight as is the bracket and B) that exhaust pipe has been heated up and cooled many, many times. It's not going to give up very easy. Get you some PB Blaster, soak the joint very well and let it soak for a couple hours. You're also going to need a big ass dead blow hammer to pound the muffler to get the muffler off. Just because it's bolted on doesn't mean it's going to be easy. Which is one of the reasons why I had my pipes cut off and the new cat back welded on.
