new tire help - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 08-18-2013, 07:40 PM
stikes stikes is offline
Vehicle: 2007 ram
stikes is on a distinguished road
Default new tire help
I have a 2007 quad cab ram with stock 275/60/20's. I keep it in the garage and barely fit as is. I want to keep my stock rims without lifting or leveling the front as to keep the same height. My question is would 285/55/20 toyo at2's extremes fit without any rubbing issues? I know that toyo makes the at2's in oe size but they dont make them in the extremes. Is there really a huge difference in looks between the two? thanks for the help
Old 08-19-2013, 11:01 AM
hollonator's Avatar
hollonator hollonator is offline
Vehicle: 2007 Dodge Ram 1500
Trim Level: SLT Quad Cab 4x4
Color: Flame Red Clearcoat - R4
hollonator is on a distinguished road
I don't know about EXACT measurements being a metric size. But I use this sight to convert back and forth and find what I want that will fit my requirements.
http://www.extremeterrain.com/wrangl...alculator.html
2007 Dodge Ram 1500 SLT Hemi 4x4
Custom Flowmaster 50 Series HD Exhaust
Old 08-19-2013, 01:06 PM
brandonjansen's Avatar
Moderator
Trim Level: Laramie Limited
Rep:2140
The 285/55/20's will be slightly shorter than your stock 275/60/20's. So you shouldn't have any issues with rubbing whatsoever and you'll still fit in your garage no problem.
Old 08-19-2013, 05:02 PM
Vehicle: 2007 ram
thanks for the info. will the wider tire be a problem with rubbing the a arm? any rub at full lock of the steering?
Old 08-19-2013, 07:06 PM
Moderator
Rep:2140
A 285 is only about 3/16" wider on either side than a 275. So as long as you have more clearance than that (which I'm sure you do) you won't have any issues running it.
