2012 front diff swap - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > Dodge Ram 4x4 - Offroad Discussion
Old 08-18-2013, 09:22 PM
bigrigg's Avatar
bigrigg bigrigg is offline
Vehicle: 2012 Dodge Ram 1500 5.7 hemi
Trim Level: sxt
Color: metalic silver
bigrigg is on a distinguished road
Default 2012 front diff swap
okay so 2012 ram 1500 4x4 and i need to change the gears but cant. Has anyone swaped there front diff out yet? is it a direct swap or dose it need modifications? and do you need to have the drive axles from the diff u use or can u use the ones off of the 2012? im looking to change it out as i found a really good deal on a 2011 front diff!!
Old 08-19-2013, 02:44 AM
ArmyRXP's Avatar
ArmyRXP ArmyRXP is offline
Vehicle: 2011 RAM 1500 SPORT
Color: Deep Cherry Red
Rep:21
ArmyRXP is on a distinguished road
Why would you change the front dif out? You can get the gear set for it easier than you can the ZF rear end. I might be wrong here but Candy or someone might chime in and let you know.
Gary
Old 08-19-2013, 10:47 PM
Vehicle: 2016 dodge bighorn 1500 hemi
Color: MAXIMUM STEEL
Rep:783
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
what gear ratio are you wanting to install?
Old 08-20-2013, 02:43 AM
bigrigg's Avatar
Trim Level: sxt
im gonna throw in 4.56's im gonna lift the truck 6 inches and throw on 37's so i need the 4.56's gears in it
Old 08-20-2013, 12:12 PM
brandonjansen's Avatar
Moderator
Trim Level: Laramie Limited
Rep:2140
Andrew (fastNugly @ BP) has done it. He'd be the guy to talk to.
You can't change the gears in the front diff in the '12 and up trucks. You need a front diff from a 2011 in order to change them.
Old 08-20-2013, 02:03 PM
ArmyRXP's Avatar
Rep:21
Brandon,
Got it, guess I missed that along the lines. So what diff is in the front then? Not sure why the aftermarket has not keyed in on this and start making sets for our trucks since RAM did so well last quarter. Seems like enough out there to make it profitable. Probably not going to change mine if I do something might be out by then.
Thanks for the correction, good looking out.
Gary
