Old 01-21-2011, 09:33 AM
ABD26's Avatar
ABD26 ABD26 is offline
Vehicle: 2010 Dodge Ram 5.7 Crew 4X4
Rep:176
ABD26 has a spectacular aura aboutABD26 has a spectacular aura about
Default Need Feedback - 285/65/20 or 305/55/20 for my Big Horn 4X4 with a 2.5" Daystar
Gents,
I'm looking at upgrading my tires. My guess is that there is a thread already on this topic, I just have not found it yet. I've got a Big Horn 4X4 with an "almost leveling" 2.5" kit.
Between 285/65/20 and 305/55/20, which is preferred?
The tire I am looking at is the BF Goodrich All Terrain T/A KO. Specs are as follows:
285/65/20 is a 34.7" tire.
305/55/20 is a 33.4" tire.
Questions:
1. Are there other brands I should be looking at?
2. I want height without the rub. Is the wider tire or the taller tire more likely to cause a rub?
3. Which looks better to you?
4. Anyone have photos of a similar set up? I think the 305's are more common; however, the 285's are where I am leaning.
Thoughts?
Thanks.
"A two-year-old is kind of like having a blender, but you don't have a top for it."- J. Seinfeld
Old 01-21-2011, 10:48 AM
Rep:1625
hpc3 has 305 BFG's on his red Ram: http://www.ramforumz.com/showpost.ph...2&postcount=20
Neither of those tires will cause rub.
I like the 285's, that's just my personal preference. Here's some pics of the 285's (first 3 pics are BFG's):
Old 01-21-2011, 10:55 AM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
305. Anything smaller is
Old 01-21-2011, 11:21 AM
ABD26's Avatar
Rep:176
Thank you for the feedback. Especially the photos.
Old 01-23-2011, 08:24 AM
ewb's Avatar
ewb ewb is offline
Vehicle: 2013 dodge ram cc
Rep:171
ewb has a spectacular aura aboutewb has a spectacular aura about
I think it all depends on what your complete setup is going to be. such as, if the wheel stick out are you concerned about rock chips hitting the sides of your truck? Are you getting fender flares? Are you concerned about gas mileage or performance? The weight of the wheels? There are so many veriables? Some guys like the wheels sticking out some dont. And I used to have nittos and the tread is more spaced out than my now wrangler AT's. which means they pick up more rocks. My wranglers I do love but the tread is closer together so I sometimes have to get a knike and dig out some little rocks but then again, Im anal. lol
Walter
Old 01-23-2011, 11:12 PM
ABD26's Avatar
Rep:176
I want a tough look. I am not getting fender flares. Mileage over performance. I'd like to heighten the truck a little to with the new tires. I don't need the tires to stick out too much. I'd like to protect the paint. Thoughts?
Old 01-23-2011, 11:45 PM
Frtman Frtman is offline
Vehicle: Dodge ram 1500
Frtman is on a distinguished road
Well i wouldn't get the wider 305's then, my old jeep had wide tires on it and yea it looked great but the clear coat around the fenders had been completely chipped away after a year
Old 01-24-2011, 08:39 PM
old hot rod's Avatar
old hot rod old hot rod is offline
Rep:386
old hot rod is just really niceold hot rod is just really niceold hot rod is just really niceold hot rod is just really nice
Send a message via Yahoo to old hot rod
Damn nice pics city slicker
Hell Bent Steel Leveling kit, K & N filter, Tinted Windows,
Mufflex DOD18M, Mopar Intergrated Trailer Brake,
DiabloSport Predator (U7137) 180 Thermostat, WeatherTech Vent Visors
DiabloSport Catch Can (C-1040)
Old 01-25-2011, 11:48 AM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
If they are 305 trail grapplers they rub mine did had to get 1/4 in. spacer. But if they are street tire you'll be fine.
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 01-25-2011, 12:09 PM
The 285 will be a bit narrower so not so much stuff will be hitting the body coming off the tires. Still, you will have some tread out past the wheel well opening.
These are 285/758RX18's on an 18X9 KMC XD Addict wheel with a +18 offset so you can see a bit of tire does come past the body line:
A 285 section width tire = approx. 11.2204"
A 305 section width tire = approx. 12.0078"
So the 305 tire is approx. 3/4" (.7874") wider than the 285
