Old 08-19-2013, 01:27 AM
GIGEMRAM's Avatar
GIGEMRAM GIGEMRAM is offline
Vehicle: 2001 dodge ram 1500
GIGEMRAM is on a distinguished road
Angry P0505 code WILL NOT GO AWAY!!! HELP
Hello, I have a 2000 dodge ram 1500 5.2 magnum automatic
I bought it for 1100 bucks with 128k on it. It had some normal
Issues such as crankshaft position sensor was bad. Needed a new battery
Shocks etc. I had three codes at first and got it down to one the p0505 which
Is the IAC I have put three IAC on the truck checked the wiring checked the vacuum hoses everything. The light will not go off. The truck runs great. It wouldn't idle at first but since the 3rd IAC it starts right up and runs perfect I've disconnected the negative to clear it. Even had a scanner clear it and as soon as I started it up it came back on. Inspections fixing to go out and I need it gone. Please help, I hope I'm not dealing with a PCM problem
I feel like if I can get rid of this I scored a pretty good deal
Old 08-19-2013, 01:41 AM
GIGEMRAM's Avatar
Anyone please help!!!
Old 08-21-2013, 12:19 PM
tjbiker031's Avatar
Vehicle: 2002 Dodge Ram
Trim Level: SLT - Quad Cab
Color: Graphite Metalic
Rep:118
What does that mean?
The IAC (Idle Air Control) valve controls the idle speed of the engine. At idle the throttle plate is closed, of course. The IAC is computer controlled and allows only a certain amount of air around the throttle plate. This metered air controls the idle speed. The IAC has a "plunger" or "shutter" that moves to open or close the bypass air passageway.
The more air the IAC allows around the throttle plate, the higher the idle. The PCM (Powertrain Control Module) uses the IAC valve to keep the idle speed correct with varying engine demands. Can be a three or four wire sensor depending on the model.
The PCM monitors voltages of the IAC circuits and if it detects an incorrect voltage on one or more of the IAC motor circuits it will set P0505. NOTE: Problems with the IAC would only be noticeable at idle or when throttle is closed.
Symptoms
Symptoms may include:
  • MIL (Malfunction Indicator Lamp) illumination
  • Engine stalls and may not idle unless throttle is depressed
  • Intermittently stalls when letting off the throttle
  • Engine may idle too high
Causes
Potential causes of an P0505 code include:
  • IAC motor connector is damaged (check connector and pins for damage, and moisture)
  • One or more IAC circuits open or shorted to ground <--Suspect this
  • One or more IAC circuits are shorted to voltage <--Suspect this
  • IAC has failed
  • PCM has failed
Possible Solutions
This should be a fairly straightforward diagnosis. Start by clearing the fault codes. Then unplug the IAC and start the engine (This may cause other IAC codes to set. Just ignore them for now). If the P0505 code doesn't reset, replace the IAC. It is internally shorting one of the IAC circuits. If the code DOES return after unplugging the IAC and starting the engine, then you know it isn't the IAC motor. Visually check the wiring harness all the way back to the PCM. You may need to visually inspect the harness by removing all the insulation off the wires. It is possible that the wires could be shorting to eachother or to other wires in the harness.
If there are no wiring problems, and the code keeps returning with the IAC unplugged, you can check the PCM by removing the IAC wires from the PCM connector (or clipping the wires in a location where they can be repaired easily) and then start the engine (If you're not sure, don't do it. Take it to a qualified professional). Now if the code doesn't reset there is a problem with the wiring. Check for continuity on all the IAC wires. Any resistance points to a problem. Check for voltage on any(At this point there shouldn't be any voltages on the wires because they're clipped at one end and unplugged at the IAC). Repair as necessary. But if the P0505 code DOES reset after removing the IAC wires from the PCM connector(or clipping them), replace the PCM, there's a problem internally on the IAC control circuit.
If you replaced it already with known good or new units, inspect wiring and check voltages going into and out of the unit. also double check voltages at PCM going to IAC and from to varify correct voltages. Getting a factory manual (not Haynes or Chilton) or a Mitchel1 manual will help you greatly
If this seems to be an overwelming task, taking it to a (reputable) professional may be your answer.
5.2 liter, check engine light, codes, iac
