Old 08-19-2013, 03:08 PM
teflon74 teflon74 is offline
Vehicle: 2014 1500 limited crew
Trim Level: limited
Rep:50
teflon74 will become famous soon enough
Default tires and air suspension???
Ok all I wanna put on some LT rated more aggressive tread tires on the new 14 Laramie im gonna order. So should I go with the 17" rim or the 20" rim and what tire/size recommendations would you guys have?? Its gonna have air suspension too so im not sure if that will matter? Teflon
Old 08-19-2013, 05:48 PM
randomid25's Avatar
randomid25 randomid25 is offline
Vehicle: 2010 Ram 2500
Color: Inferno Red
Rep:28
randomid25 is on a distinguished road
I've been wondering if there is a need to level out the front of an air ride equipped 1500 like the coil spring trucks. Does the front ride lower than the rear?
As for tires, I'm gonna run the 17s because they are expensive enough. 20s cost to much for my taste. I'll get the plain factory wheels and tires and sell them when the truck comes in and replace them with aftermarket wheels and tires.
Old 08-19-2013, 08:17 PM
crabjoe crabjoe is offline
Vehicle: 2014 Ram 3500
Color: Maximum Steel Matallic
Rep:62
crabjoe will become famous soon enough
I'd go 17s with LT tires... More sidewall can give you a softer ride..
Old 08-20-2013, 05:51 PM
Bushmaster's Avatar
Bushmaster Bushmaster is offline
Vehicle: 2014 Ram 1500
Trim Level: Outdoorsman 4x4 CC
Color: Bright White Clearcoat
Rep:83
Bushmaster will become famous soon enough
Just ordered my 2014 Ram 1500 Outdoorsman and it comes with the factory 17" rims with LT tires already on it, they are the Goodyear Wrangler SilentArmor.
Are you going to a more aggressive one than these?
Bakflip G2 tonneau cover, SunTek clear wrap complete front end, Trail FX wheel to wheel nerf bars, Huskyliner mudflaps, Weather Tech front floor mats, rear Recon mini lightbar,20% tint front door windows, 5% tint rear door/rear window, Smittybilt Lightbar with 10" Rigid LED lightbar
Old 08-20-2013, 10:11 PM
Trim Level: limited
Rep:50
not sure, but I cant get those wheels on a Laramie, and they wont put those tires on a sport????
