Custom Sway Bar End Links - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Old 08-19-2013, 06:13 PM
cmagrey12788's Avatar
cmagrey12788 cmagrey12788 is offline
Vehicle: 2007 Dodge Ram
Rep:78
cmagrey12788 will become famous soon enough
Default Custom Sway Bar End Links
Got the idea offline on another dodge website.. using 5/8 heims and grade 9 hardware. hellwig mounting brackets that i scored off ebay. any input would be nice.. i dont really need these but i get bored when i dont have a project to work on! lol. going to get new inner bushings and clean up my sway bar too. heres a few pics. waiting for the threaded sleeves to come in and the other heim joints.
Old 08-20-2013, 11:27 AM
Vehicle: 2016 dodge bighorn 1500 hemi
Color: MAXIMUM STEEL
Rep:801
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
looks good. this is my jeep mentality, when it breaks, remove and upgrade.
Old 08-20-2013, 09:19 PM
Rep:78
Thanks. yeah, my stock tie rod ends are alittle worn out on the upper bushing. normal wear. the bottom joint that is like a ball joint is on a pretty bad angle. i just figure build a better working/looking solution
Old 08-20-2013, 10:22 PM
Rep:801
might be a good side line bussiness for you.
Old 08-21-2013, 09:09 AM
battlerattle's Avatar
Vehicle: 2016 Ram 2500 Laramie LongHorn
Trim Level: Laramie LongHorn
Color: Granite
Rep:286
Lol, I did something similar on my jeep. The rod ends work well and allow great adjustability. Downside is they will get noisy fast. Doesn't matter how clean you keep them, they will get noisy.
Just Got it, Give me time!
Old 08-21-2013, 04:30 PM
Rep:78
how noisy?? what kind of noise??
Old 08-21-2013, 05:34 PM
Color: Granite
Rep:286
You will here them over every bump after about a month. Keeping them greased helps, but not much. goes from a metalic squeak to a clanging depending on how dry they are and how far they wear.
On the bright side they actually do work really well!
Old 08-21-2013, 08:42 PM
Rep:78
well that sucks! if i end up not liking them i will probly just sell the setup on here and go back to stock. that sucks that they make so much noise it costed alot to make these! lol i was thinking about trying those rubber boots over the heims that they make to keep them clean
Old 08-21-2013, 10:06 PM
Rep:801
let us know how they work out.
Old 08-29-2013, 05:53 PM
Rep:78
finally got the female ends in the mail today. just got to get a new set of bushings for the sway bar itself then i can put it all together. should look good. also i put some coins in the pic just for a size reference.
