Possible replacement - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Old 08-20-2013, 11:48 AM
Designflaw's Avatar
Designflaw Designflaw is offline
Vehicle: 2013 Ram 1500 4x4 Sport
Rep:40
Designflaw is on a distinguished road
I have always heard that around 100,000 miles or so there are front end issues. I never had any, but I traded mine at 71,000. May research that a little.
IF you don't mind I'm curious what they are selling it for. My 05 Quad started with a trade in offer of 21,000 I told them to pound sand, ended up with 25,000 and they sold it for 29,000 this past December. It was on the lot 3 days.
2013 CC Sport 4x4: 3.55, 20% Tint, Line-X, fender flares, mud flaps, Weather Techs, bed cover, 2.5 Leveling kit, Blacked out emblems, Vararam Air Grabber
2008 M109R LE, 1999 TL1000R, 2003 Yamaha Golf Cart :hah:
Old 08-20-2013, 12:10 PM
Vehicle: 2016 dodge bighorn 1500 hemi
Color: MAXIMUM STEEL
Rep:783
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
dealers near me have a waiting list for 5.9 cummins in trucks that are in good shape and sell close to the same price as they did when new. never make it onto to the lot.
Old 08-20-2013, 06:17 PM
Kcbigbadram's Avatar
Vehicle: 2007 1500
Trim Level: Big horn
Color: Inferno red
Rep:503
its gonna be awfully hard going from all the upgrades of a 4th gen laramie to a 3rd gen, but im sure youll enjoy being back in a cummins
Old 08-20-2013, 06:39 PM
Arth's Avatar
Arth Arth is offline
Vehicle: 2006 Chevrolet Avalanche
Color: Bronze Alloy Metallic
Rep:2035
Well they are asking 18,500 for this truck.
I don't consider myself an expert but I have access to a shop/lift and anything else that would be required. I checked it out pretty thoroughly and I feel confident in it.
What other things would a diesel mechanic be able to do more than me?
I checked the ball joints and they are good. Did the redneck method but each wheel held firm in place. Checked tranny fluid, oil level/fluid, underneath the truck for obvious signs of leaks between the block/transmission/differentials. Confirmed that the power steering pump is new. Also checked the drive shaft/u-joints and there was no play. Brakes/rotors are in good shape. It has new tires..Michelins.
It is a 2wd truck which is fine for me. Pulled the build sheet and it has the 3.73 rear end with anti spin and that is what I have now basically.
Am I missing much else? Please advise!
Chrome... in moderation.
Old 08-20-2013, 06:56 PM
Asur Asur is offline
Vehicle: .
Rep:4373
If you have an expert Diesel guy look at that truck, make sure he inspects the fuel delivery and filtration system, you might even want to get to it as a first mod and upgrade it to something better than OEM, there are also known issues with that truck and the injectors, usually needing replacement every 60000 miles. This is an area you can also upgrade. Yes as another one pointed out have the ball joints checked by a pro, but also the whole front end, these 04's are know for u-joint problems and tie rod ends, 18.5k to me is a bit high for a 136k miles truck, yes is the 5.9 but depending on trim there might be some room for some negotiations, if you spoke to the previous owner how much did they give him for his truck? But for sure if its in great shape, you should have a smile on your face every time you floor it. JMO, and all the best in your possible purchase.
Old 08-20-2013, 08:47 PM
Rep:783
100000 miles is the mileage that the valves need to be adjusted. in my area that truck would be snatched up as is for that price. diesel mechanic may be able to tell you if had hp tune used and if it was worked hard. but it doesn't look like it was used for heavy work. looks like a great find.
Old 08-20-2013, 10:24 PM
Hermes1 Hermes1 is offline
Vehicle: A Truck
Rep:2559
Asur nailed. For me the injectors are worth having checked out as would be the ball joints. Not that any of this should scare you away from what appears to be a super buy, but just to be aware and minimizing any surprises. Good luck to you in whatever you decide.
Old 08-23-2013, 08:14 PM
Arth's Avatar
Rep:2035
Looks like I am gunna go through with it.
They are selling it for $17000. Per my request they are putting in two new batteries. Truck has new tires and needed little else. It is a SLT which is pretty basic compared to my Laramie but I don't care.
I needed to drop down as far as amount owed due to my daughter.. family comes first. I will however still be owning a truck.
I will be changing the oil/fuel filter once I actually have it and possibly dropping the transmission pan. This is all easy things for me to due since I have access to a shop.
Old 08-23-2013, 09:03 PM
PappaJohnRam's Avatar
PappaJohnRam PappaJohnRam is offline
Vehicle: 2003 Ram 1500
Rep:563
PappaJohnRam is a name known to allPappaJohnRam is a name known to allPappaJohnRam is a name known to allPappaJohnRam is a name known to allPappaJohnRam is a name known to allPappaJohnRam is a name known to all
Without a doubt, a daughter means more than a truck.
Congrats on finding a replacement you're happy with and a good deal to boot. Best of luck, enjoy it!
Pappa John
Old 08-24-2013, 12:29 AM
Rep:783
good for you. enjoy.
