11 mpg! - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 08-20-2013, 07:30 AM
OXlvsMPR85 OXlvsMPR85 is offline
Vehicle: 1999 Dodge Ram 1500
Trim Level: Larime
OXlvsMPR85 is on a distinguished road
Default 11 mpg!
Just bought my 99, 1500, 5.9 and I already replaced the crank seal and rear main seal, the truck runs great but the mileage is horrible. I plan on doing a tune up but when I search for a tune kit (ie: plugs, wires, cap and rotor) there are so many options for how hot the plugs burn or what not.... I'm trying not to go with OEM on this and I'm not looking for a entire ignition system, but if anyone might know how hot of a plug and coil a 5.9 can run that would be great or even just a good tune kit. Thanks for your time everyone.
Old 08-20-2013, 06:39 PM
panhead's Avatar
panhead panhead is offline
Vehicle: 2005 Dodge Ram 1500
Trim Level: SLT w/ Sport Pkg
Color: Sollar Yellow
Rep:103
Stay away from Champion spark plugs. Full tune up (cap/dis rotor, wires, Autolite spark plugs). Get an ignition coil, either from Mopar or Accel. Replacing O2 sensors will improve MPG's.
Old 08-20-2013, 10:47 PM
the persuader's Avatar
Vehicle: 2001 Cummins 4x4
Trim Level: SLT Laramie
Rep:326
Is that 11 mpg in town? If so, that might be the best you're gonna get. These trucks aren't great in the gas mileage department. My truck gets 10-11 city, 13-14 hwy
If it is highway, you have issues. I once got 9.5 mpg on the highway when my plenum gasket was bad.
Old 08-21-2013, 12:04 AM
richmond richmond is offline
Rep:177
richmond has a spectacular aura aboutrichmond has a spectacular aura about
Default Ditto that of Panhead & Persuader
I did Autolite plugs and Mopar ignition coil the last time (2 years ago). I've been running town trips in my 98 Larime 5.9 4X4 Quad grabbing parts for a truck I picked up. My 5 trips into town and back, the best I could muster was 10 mpg. I cracked 15mpg once going to Louisville and back. Like Persuader I'm happy with my truck, crappy mileage and all. I think we're probably stuck in this range (as long as we keep'em in tuned up).
R...
Old 08-21-2013, 08:11 AM
Trim Level: Larime
Well that all makes sense... we all did not buy these trucks for the mileage, but i drive it mostly on the highway. I do however need my timing cover, and plenum gaskets replaced. While that's all apart I'm going to replace the thermostat and O2 sensor and see how we do after that.
Old 08-21-2013, 11:02 AM
Rep:326
My Hughes plenum kit came with a thermostat, but it looks like they don't include them anymore. I will say that I was impressed with the kit. Came with everything I needed except for blue threadlocker and RTV.
http://www.hughesengines.com/Index/p...p?partid=27091
If your 02 sensors are bad, that can cause a gas mileage drop.
Old 08-21-2013, 12:13 PM
tjbiker031's Avatar
Vehicle: 2002 Dodge Ram
Trim Level: SLT - Quad Cab
Color: Graphite Metalic
Rep:118
Exclamation
I will tell you that with new O2 sensors you MAY see slightly better IF they are bad. Honstly those dont go bad that often unless you are running the engine rich
As far as the thermostat goes. Buy an OEM one. If you get one that runs the engine colder (or warmer) than the OEM spec are...you WILL get horrible gas milage. Running a "cooler" Thermostat will hinder performance by not allowing it to reach proper operational temp to properly burn A/F mixture...along other emission issues it will cause also tearing up MPG efficiancy. The old-timers sayin that running a cooler or colder thermostat will help your engine last is a myth and will eventually destroy your engine.
Old 08-21-2013, 10:09 PM
05SilverStreak 05SilverStreak is offline
Vehicle: 1998 Ram 1500 5.9
05SilverStreak is on a distinguished road
Sounds great! My 98 gets a whopping 14mpg going downhill with the engine off and wind behind it.
Old 08-21-2013, 10:23 PM
Gantman's Avatar
Gantman Gantman is offline
Vehicle: 2016RCLB4x4/44-45
Trim Level: Tradesman w/3.92 LSD
Rep:999
Man you get slightly better average than my old 99 5.9 Magnum. I barely averaged 10 city/hwy mix when I had her. But I drove it like I stole it back in those days.
Total Chaos UCA's, Fox 2.0 IFP Coilovers and shocks, TTC-1223V variable rate coil springs.(Mods list)
Old 08-23-2013, 11:57 AM
tmaxxs10 tmaxxs10 is offline
Vehicle: 1998 Dodge Ram
Color: Green
tmaxxs10 is on a distinguished road
Go wit the Hughes plate kit or the air gap intake. I would also do a timing chain while you have the cover off. You may as well do a water pump since it's off. As for plugs I think I am going to try ngk plugs or molar performance. From experience replace as much as you can if you have it apart.
