Old 08-20-2013, 10:24 AM
Green01 Green01 is offline
Vehicle: 2001 Ram 1500
Color: Green
Green01 is on a distinguished road
Default Spare question
I have a 2nd Gen with stock 4th Gen 20" wheels. I want to add a 20" spare but not sure if it will fit in the stock spare location. Has anyone fit a 20" in the stock spare location?
Old 08-20-2013, 04:10 PM
RogerRamJet's Avatar
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
Wheel size isn't as important as tire size. What size is your tire?
Old 08-21-2013, 02:33 AM
Color: Green
Tire size is the stock tire on the 20" wheels, if I remember correctly it might be roughly a 33" tire.
Old 08-21-2013, 09:18 AM
Rep:2929
If it's stock, then it's probably a 275, which translates to about 31". But I think even a 33" would fit up under the bed.
Old 08-21-2013, 10:00 AM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:554
275 is the cross sectional width,
has nothing to do with diameter unless you have the aspect ratio
a stock 275/60R20 is 275mm cross sectional width, translates to 10.826" wide
x 60% (60 is aspect ratio) = 6.495" Sidewall height
Sidewall x 2 (top and bottom) = 12.99" + wheel diameter (20" ) = 32.99"
My stock spare is a temporary use 235/85R17
the overall diameter is 32.7" almost the same as a 275/60R20
Some guys were picking up a full size chrome clad 20"
removing the plastic chrome cladding and using that on a 4G
The bore of the center hole is larger on the steel wheel,
(no cladding material in the way)
A chrome clad 20" wheel has the cladding blocking part of the bore and wont work unless you peel off the clad.
So you either need a smaller T,
or get a black steel 20" wheel/spare from a 3G Hemi.
(my 04' had Polished Aluminum 20's and a black steel 20" spare and full sized 275/60R20 good year tire)
Old 08-21-2013, 01:25 PM
Color: Green
Thanks, the wheels are the non clad 5 spoke.
Old 08-21-2013, 08:45 PM
Outlaw's Avatar
Outlaw Outlaw is offline
Vehicle: 2014 Ram 1500 RCSB
Color: Bright white
Rep:435
Outlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really nice
Stock tire size will fit. The rim center bore may be too small for the bracket on the cable to fit thru but the tire itself will fit.
[CENTER][SIZE="4"][COLOR="green"]2014 RAM 1500 RCSB BRIGHT WHITE[/SIZE][/COLOR]
[/CENTER]
Old 08-23-2013, 12:39 AM
Explorer Rob's Avatar
Explorer Rob Explorer Rob is offline
Vehicle: 2013 Ram 1500 4x4
Trim Level: Laramie Longhorn
Color: Black Gold / White Gold
Rep:264
Explorer Rob is a jewel in the roughExplorer Rob is a jewel in the roughExplorer Rob is a jewel in the rough
My 2013 Longhorn came with a 275 60R20 spare on a 20" black steel wheel.
Old 02-01-2014, 12:24 PM
PJRNM's Avatar
PJRNM PJRNM is offline
Vehicle: 2012 Ram 1500
Trim Level: SLT Bighorn
Color: True Blue
Rep:17
PJRNM is on a distinguished road
x2 on removing the cladding. I did this yesterday and there are no fitment issues.
