Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Dodge Ram Decals
Old 08-20-2013, 05:15 PM
Edfiremed Edfiremed is offline
Vehicle: 2003 Dodge Ram 1500
Trim Level: ???
Color: Tan
Edfiremed is on a distinguished road
Default A/C not working at Idle
2003 Dodge Ram 1500 AC runs fine while driving or idling at high RPM but blows warm air during idle. Low pressure hose is at 100 psi while compressor is on. With gauge on and hitting high idle the pressure drops to within normal range 45-55 psi. Compressor stays on all the time and does not cycle off. WHat can be my issue? The AC cooling fan seems to be working fine.
Old 08-21-2013, 05:14 PM
RogerRamJet's Avatar
RogerRamJet RogerRamJet is online now
I do it because I can!
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
Racking my noodle, and all I can come up with is the compressor is starting to show signs of it's age and not compressing the gas well enough at low rpm's.
Old 08-21-2013, 06:47 PM
the persuader's Avatar
Vehicle: 2001 Cummins 4x4
Trim Level: SLT Laramie
Rep:326
Since you have an 03, your condenser fan probably took a dump.
Old 08-21-2013, 10:48 PM
Rep:2968
Perhaps I read the op wrong when he said the AC cooling fan seems to be working fine. I took that as the condenser fan because he said at high idle it blows cold. Perhaps we need some clarification.
Ed, when you say the AC cooling fan seems to be working fine, do you mean the condenser fan (engine compartment) or interior fan (blower motor)?
Old 08-21-2013, 11:15 PM
Rep:326
You're right, I missed the part about it blowing cold at a higher idle.
Old 08-29-2013, 07:41 AM
tjbiker031's Avatar
Vehicle: 2002 Dodge Ram
Trim Level: SLT - Quad Cab
Color: Graphite Metalic
Rep:118
Sounds like low refridgerant. I would have a shop recover the refridgerant, evacuate the system, perform a leak test (shouldnt cost you extra....they should be doing this as apart of the service anyways) and then charging to the proper weight of refridgerant
