Old 08-20-2013, 08:16 PM
russel 2012's Avatar
russel 2012 russel 2012 is offline
Vehicle: 2012 dodge ram
Trim Level: st
Rep:13
russel 2012 is on a distinguished road
Default rancho quick lift or bilstiens
was going back and forth on these two products ,,rancho quicklift loaded for the front and the and rs9000xi shock for the rear or bilstein 5100 adjustables for the front and the bilsteins for the rear,, got prices on both,, WHAT ARE YOUR OPIONS ON THESE TWO PRODUCTS THANKS ALL
Old 08-20-2013, 08:51 PM
h2oman's Avatar
h2oman h2oman is offline
Vehicle: 2012 Ram 1500
Trim Level: Express 4X4
Rep:358
Nothing wrong with Rancho but, Bilstein races all over the world. Whichever you prefer.
333Half the beast
I used to be
Old 08-20-2013, 09:16 PM
05cr125r's Avatar
05cr125r 05cr125r is offline
Vehicle: 2012 Big Horn QC
Trim Level: Big Horn 4x4
Rep:116
bilsteins...get the best from the get go
Mods; Line X, Bilsteins set at 2.1, Magnaflow 18", Debadged , Cool White LED Interior, LED license plate, Cool White LED reverse, Fronts tinted 20 %, Stubby Antenna,AVS WindowVisors, Black Honeycomb Grille Insert, Green Performance Air Filter
Old 08-20-2013, 10:10 PM
ExpensiveToys ExpensiveToys is offline
Vehicle: Ram
Rep:7
ExpensiveToys is an unknown quantity at this point
Oh oh....another religious debate.
I have one truck with bilsteins shocks and have rancho's quicklifts on my 2011 1500. I think both are great products. I like the rancho's 9000xl on my 1500 as I can easily adjust my ride, was able to find someone local who sold and installed them (so they also will warranty them). Rancho also offered the 90 day love the ride or they pay to put it back warranty. (check with your installer). So was able to get the quicklifts put on my truck and if I ended up having problems with ride after install could get my money back. Didn't have any problems, but it was nice to know I had the extra insurance.
Still have bilsteins on my other truck. Only gripe I had with bilstein is that no one local installs/warranties them and they want you to go through company your purchased them from for warranty. Problem is the shop I bought them from is long gone. So when I had a seal failure on one of them, bilstein made me ship it in to get it warrantied. Since at time I couldn't do without the truck just ended up buying a new shock.
If I didn't have a local installer/service center that sold rancho's I would have to ship one of their shocks in as well to get warrantied. So even if you are doing the work yourself, check around and see if you have a local service center that sells them (whatever you decide to go with, even if you don't buy it local) so you can get a shock replaced under warranty without having to have truck sit on the sideline waiting for UPS.
Used to be that you could put a deposit down and companies would drop ship a new one, and you could send an old one back. But seems to be getting to be a less common option.
Old 08-22-2013, 01:28 PM
Spike Spike is offline
Vehicle: 2013 RAM Big Horn 4x4
Rep:58
Spike will become famous soon enough
I lean towards the Rancho because it comes assembled with the spring (unless my research on this has led me astray). The best combination is always going to be matching the spring rate with a damper. I would assume that Bilstein did their homework on this but then again, they may use the same damper characteristics for a range of vehicles.
The Rancho's are pretty pricey and Bilstein damper are very good products. Either way, you win.
2.5" Lift, 305 R20's, Winch, Softtoper,
K&N, ZJ in tow, German Shepherd co-pilot
Old 08-23-2013, 08:57 AM
2010renegade 2010renegade is offline
Color: Maximum Steel
Rep:28
2010renegade is on a distinguished road
Rancho loaded struts and shocks all the way, much easier install, fully adjustable dampening, all put together for you. Have them on my truck could not be happier, they cost a bit more but worth it.
Old 08-25-2013, 11:15 AM
Imakebrakes Imakebrakes is offline
Vehicle: 2011 ram 1500
Imakebrakes is on a distinguished road
I like the blistens
