Old 08-20-2013, 09:13 PM
bguraluick's Avatar
bguraluick bguraluick is offline
Vehicle: 2014 Dodge Ram Sport
bguraluick is on a distinguished road
Default Question about lift/tires
Hey guys, this question has probably been answered 16,000,000 times, but I put a 2" front leveling kit on my 2012 ram sport and was wondering what size of tire to put on. I want a more aggressive mud/trail tire and was wondering what would look best and best bang for my buck. Any suggestions would be appreciated!
Old 08-20-2013, 10:04 PM
chadster21's Avatar
chadster21 chadster21 is offline
Vehicle: 2012 dodge ram
Trim Level: sport fully loaded
Color: charcoal grey
Rep:108
chadster21 will become famous soon enoughchadster21 will become famous soon enough
35s... some wheel spacers or offset rims will be needed
6'' rcx lift, 1.25'' rcx body lift, pro comp adjustables at 2.75'', 1.75'' tgc coil spacer. 37'' toyos on 20'' fuel hostages. mufflex 14 cai
Old 08-20-2013, 11:12 PM
bguraluick's Avatar
Im looking into some toyo mt's. Is there a size that wouldn't require spacers or offsets?
Old 08-21-2013, 02:42 AM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2032
285 is typically the widest you can go without any wheel spacers. Some guys do get away with more though, it depends on the truck.
But as Chad said, 35x12.5's with 1/4" wheel spacers would look the best. Otherwise aftermarket rims with the correct offset.
Old 08-21-2013, 10:04 AM
bguraluick's Avatar
stupid question, but 1/4" all the way around?
Old 08-21-2013, 12:16 PM
Rep:2032
Technically you only need them on the front to clear the upper A-arms. But I would do them all the way around otherwise the difference in poke between the front and back wheels will be even bigger than it is stock.
Old 08-24-2013, 12:10 AM
2"level and 35's will be tight and will require some modification.
Typically 2.5" is required and is already a tight fit.
If just a 2" level I'd go for a 34" equivalent tire or 34.5" tire like the nitto trail 295/65/20
If you need pricing on tires or leveling kit, let me know
fastNugly@bullysperformance.com
Old 09-02-2013, 11:35 AM
Fatty Matty's Avatar
Fatty Matty Fatty Matty is offline
Vehicle: 2011 Ram 1500 Crew Cab 4x4
Color: Brilliant Black / White Gold
Fatty Matty is on a distinguished road
The Nitto Trail Grapplers that I'm watching on eBay (I don't need new tires yet) say that they're over 35"....
Size
295 65 R 20
STOCK #
N205-790
INF. OVERALL DIA.
35.47"
OVERALL WIDTH
12.13"
MAX LOAD
4080LBS @ 80PSI
I have a leveling kit installed and my wheels are a +10 offset. Now I'm wondering it those tires will fit....
Current: Debadged / 1.75% tint / 18" Magnaflow & Y-Pipe / TGC Leveling Kit / Paramount Restyling grille / Bakflip G2 / 34" Cooper Zeon LTZ / Vararam / EGR in channel Vent Shades / Husky WeatherBeater mats
To be installed: 20" DUB Drone 6 wheels / Go Rhino Dominator 2 steps / EGR fender flares
Next: programmer
Old 09-02-2013, 06:21 PM
Size
295 65 R 20
STOCK #
N205-790
INF. OVERALL DIA.
35.47"
OVERALL WIDTH
12.13"
MAX LOAD
4080LBS @ 80PSI
You are right and it was my typo.
It is 35.4
Let me know if you need pricing on the tires
Old 09-03-2013, 09:02 PM
bguraluick's Avatar
so with only a 2" level kit in the front, I should be looking at 33 or 35? sorry i'm kinda new at this. 33x12.50xr20ish? thanks for all your help!
