Old 09-07-2013, 07:18 PM
Denise63 Denise63 is offline
Vehicle: 2013 Dodge Ram 1500
Denise63 is on a distinguished road
Default offset question
Hi everyone! Newbie here and I am hoping someone can help me out I have a '13 ram 1500 sport with NO leveling kit or lift. I am wanting new rims and have found some with a -12 offset. The backspacing is 4.53 I believe. I have 275/70R18 tires I need to use. I would like them to stick out a little more than the factory wheels/tires, but I have to be careful because I drive on gravel everyday. I have been told by some tire shops that this won't work and others say it will be fine. I don't know what answer is correct
Thanks in advance for any help!
Denise
Old 09-07-2013, 09:46 PM
Lifted Cummins Fanatic
Rep:2032
Those tires are only 33.2"x10.8" which is only slightly larger than stock. You'll be able to fit those no problem on an 18x9 -12 offset rim. Keep in mind that they will be sticking out over an inch further than the stock wheel/tire set up.
Old 09-07-2013, 09:50 PM
LowUFO's Avatar
LowUFO LowUFO is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Sport Crew
Color: True Blue Pearl
Rep:1109
Your new rims will sit 31mm further out than stock 20" rims. No issue other than rocks being thrown onto the side of the truck.
Bilstein 5100s @ 2.1", CF wrapped dash, De-badged, Extang Solidfold tonneau, Goodyear Wrangler Duratracs (285/60/20), Husky Weatherbeaters, Magnaflow 18" muffler, Mufflex 5" tips.
Old 09-07-2013, 10:14 PM
Thanks for the help!
Old 09-09-2013, 12:01 AM
Both answered it
