Old 09-03-2013, 11:13 PM
Originally Posted by bguraluick View Post
so with only a 2" level kit in the front, I should be looking at 33 or 35? sorry i'm kinda new at this. 33x12.50xr20ish? thanks for all your help!
With 2" leveling kit, you can fit a 33"-34" tire anymore more and it will look stuffed IMO
Old 09-09-2013, 02:00 PM
Fatty Matty's Avatar
Fatty Matty Fatty Matty is offline
Vehicle: 2011 Ram 1500 Crew Cab 4x4
Color: Brilliant Black / White Gold
Fatty Matty is on a distinguished road
You are right and it was my typo.
It is 35.4
Let me know if you need pricing on the tires
You're pretty much an expert on anything for these trucks. What tire (or at least what size) would you recommend with a 2" leveling kit? I want as tall as I can but as wide as I can too, as my wheels are only a +10 offset.
I'm not ready for new tires yet, but figured I'd ask while we're already talking about it...
[B]Current:[/B] Debadged / 1.75% tint / 18" Magnaflow & Y-Pipe / TGC Leveling Kit / Paramount Restyling grille / Bakflip G2 / 34" Cooper Zeon LTZ / Vararam / EGR in channel Vent Shades / Husky WeatherBeater mats
[B]To be installed:[/B] 20" DUB Drone 6 wheels / Go Rhino Dominator 2 steps / EGR fender flares
[B]Next:[/B] programmer
Old 09-09-2013, 02:11 PM
35's would be a tight fit.
I would recommend a 34" tire as a 35" looks stuffed with a 2.5" lift already....that is just my opinion.
34" tire could be 275/65/20. This will work with your +10 offset as well. It will only hang out 9mm further from stock, which is slightly over 1/4"
You can even do max 34.5".
It will give you the same look and appearance as a 2.5" lift and 35's
But how wide of a tire did you want to go?
Old 09-09-2013, 02:21 PM
No sure, but I am getting the EGR bolt-on look fender flares put on today and I'm afraid my tires won't stick out far enough and may look too tucked in. My Cooper Zeon LTZ's are LT275 65 20's (34.2") and I was thinking maybe a 305 60 20 might work (about 34.4")...
Old 09-09-2013, 03:07 PM
Id rather do a 295/60/20
But your EGR flares do stick out 2.5" so it will be slightly tucked under simply because of the offset of your rim.
To be flush you would need 20x9 (-12 offset) or 20X10 (-12 offset)
Running those will require some minor trimming
Old 09-09-2013, 03:49 PM
ramready12's Avatar
ramready12 ramready12 is offline
Vehicle: 2011 Dodge Ram
Rep:33
ramready12 is on a distinguished road
I have had 35's on a 2.5 level and its pretty stuffed. IMO go with the 295 60 r20. perfect size for the level.
