2002 5.9 Magnum Smokes when backing up inclines only! - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.9L V8 Specific Topics
Old 08-19-2013, 08:39 PM
davesworld0760 davesworld0760 is offline
Vehicle: 2002
davesworld0760 is on a distinguished road
Default 2002 5.9 Magnum Smokes when backing up inclines only!
So, after recently purchasing my first Ram truck (2002 5.9 Magnum) and not doing a thorough job of checking things out (price was really great), I find an interesting issue. Only when backing up, usually backing up an incline, the truck belts out a substantial amount of WHITE smoke. Plus, there is a heavy amount of burning oil odor. This only happens in reverse. Even when I rev the engine to high rpms, or just accellerating from a stop or down the highway, there is never any visible smoke. The only other issue I can find is the bolt that holds the KN air cover onto the throttle body has broken off where it screws into the throttle body. I will extract that soon enough. The smoke while backing up bothers me, otherwise the truck runs out just fine...
Help?
Old 08-20-2013, 04:32 PM
RogerRamJet's Avatar
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
Sounds like you've got some oil getting in to the combustion chamber, but from where? I'm thinking you're gonna have to take the intake off and check. If there no sign of oil there... wait a minute... do you have a catch can? If no catch can, then if there's no sign of leakage in the intake, the heads come off next. Someone else will hopefully chime in with something else. But for now, that's all I can think of.
Old 08-21-2013, 10:12 PM
Vehicle: 2002
Default Catch can
Thanks Rodger. I do not think there is a catch can on the truck. I will take a look down the throttle body to see if anything is pooling there, but honestly I am thinking there could be an issue with the 4wd works. Probably need to have someone else back it up while I get under there and take a look...
5.9 magnum, smoke
