Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion
Old 08-23-2013, 01:46 PM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:554
I maxxed my rpm limiter to 7k rpms (last I remembered). I'm back to a stock verter because i need it looser for spraying. I lost a little when running on motor but I've gotten better times consistently on a stockverter. I fried my 4.56's because I'm terrible at setting gears up, lol...with 3.92's and lower you don't have to be perfect but when you get up to 56's you have to set these up more carefully...
I hear ya, lost a few teeth myself with 4.56's in my Jeeps
and that's the one install I always leave to the experts.
There's a lot less room for error when you have fewer teeth engaged,
and the lower your ratio drops the smaller the pinion diameter gets,
...I've seen Dana 5.38's that looked like a thimble compared to stock 3.55's lol
Old 08-23-2013, 01:53 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
With a 26" tire you will be right up on your 7k rpm limit going through the gates in 3rd gear(1:1). You'd probably be better off with the 27" tire, that'll give you a couple hundred rpm buffer and a little room if you get faster. You're current M&H's should be ~28.5" diameter which isn't too bad either.
Sean
Old 08-23-2013, 02:13 PM
RadioFlyer's Avatar
RadioFlyer RadioFlyer is offline
Rep:146
RadioFlyer will become famous soon enoughRadioFlyer will become famous soon enough
Also, there's a big difference in temps between 3.92's and say 5.13's. You can tell by just putting your hand on the inspection cover after a race. I would think the higher heat adds to wear especially when they not set up just right. I use to have the same trouble, it's a pita to set them up perfect.
